Deep cycle batteries for cranking
                    706jim
                    Solar Expert Posts: 526 ✭✭✭✭
                    I have a boat powered by a 350 Chev engine. I have two group 31 starting batteries entering their 11th season and figure it's time to replace them. I'm considering replacing them with two group 31 fla's that will be paralleled all of the time. Wondering if they will have enough oomph for cranking this engine. Has anyone tried something similar?
            IMHO, it depends.
 In my experience, true deep cycle batteries do "okay" in starting applications for boats. I wouldn't count on them to start my car in the cold though.Off-grid.
            If I got 11 years the first time, I might do exactly the same thing the second time. The batteries must have stayed somewhat cool as a rule.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
            Question is, is the proposed use of deep cycle batteries to use them for loads other than starting? Doing so may reduce capacity when starting is required, otherwise there should be enough capacity to start since in parallel the plate count is double, in a pinch I've used a single 45Ah deep cycle to start my mini escavator with a 2.2 liter diesel.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
            I was just thinking that they might perform better when the boat is anchored and the electric fridge runs for a few days. I keep a Honda EU1000 as backup though.Island cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year.
            11 years is pretty good. Like softdown says, doing the same again may not be a bad idea unless the application has changed.Off-grid.
            Did the refrigerator run on start batteries when anchored, previously ?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
 In that case, deep cycle would be a lot better for loads and still provide plenty of cranking power for a 350. They may run a really small fridge for quite some time.706jim said:I was just thinking that they might perform better when the boat is anchored and the electric fridge runs for a few days. I keep a Honda EU1000 as backup though.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
            I see the OP lives in an island cottage? Been thinking about islands lately. Spent a lot of time evaluating Iceland and the islands around it. When one is really ready to say "F*** Off" to the world - there are islands off of Iceland.
 The Philippines have a few thousand islands and most are uninhabited. But I get weary of heat and humidity as my over sized head needs a lot of cooling it seems.
 There are a lot of islands off the west coast of Canada and in southern Alaska.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
            A couple of interesting things about islands...
 They tend to be highly valued for privacy, yet are accessible and viewable from 360° around them (plus view from above). Almost voyeuristic.
 Once on one, one's mental "zone of exclusion" expands greatly. An apartment might have an exclusion zone of inches, like personal space on the elevator. On an island, it's miles.
 Just an observation.Off-grid.
- 232 Forum & Website
