Q: Why would you want to allow your wind turbine to free spin?
foolios
foolios Solar Expert Posts: 53 ✭✭
Looking up brake info, I see options on the brakes.
Why would free spin be an option? I read free spin happens when loads are missing and the battery is overvoltage; which could result in the destruction of the turbine.
Switch Positions:
  • Up -- Turbine is connected to the battery or rectifier. (Switch is closed)
  • Middle -- Turbine is fully disconnected, free spinning.
  • Down -- Turbine wires are shorted together. Brake is on.
  • Estragon
    Maybe so you can work on it with circuits open, check to make sure it spins with no load, etc?
  • mcgivor
    Kind of what I was thinking, a neutral gear of sorts, to test the bearings without load or brake.
  • foolios
    Excellent.
    Thanks.
    BB. Super Moderators, Administrators Posts: 33,722 admin
    edited April 2020 #5
    A lot of double pole double throw switches have a middle position where they are off...
    Bill
