Quick question
Rthomas911
Registered Users Posts: 1 ✭
Can two 110 inverters push a 220 well pump if they are pure sound wave inverters???
Not unless they're designed to do so. Some are series stackable, but unless designed for it, there will be a phase mismatch between the two legs.Off-grid.
Stackable inverters have a "sync" cable, so that the magic smoke is not released
The short answer is definitely no.
Look at Schneider's SW4024 inverter. It has both 120/240 output to begin with, but if extra capacity is needed they can be paralleled to put out up to 14,000 watts of 5.0 second surge
https://ressupply.com/inverters/schneider-electric-conext-sw4024-120240-invertercharger
If you have a little pump (≤0.5HP) a single 4024 might start it. Two 4024s in parallel will surely start it.
I'm now running my 1.5HP well pump off a Schneider XW6848.
System 1) 15 Renogy 300w + 4 250W Astronergy panels, Midnight 200 CC, 8 Trojan L16 bat., Schneider XW6848 NA inverter, AC-Delco 6000w gen.System 2) 8 YingLi 250W panels, Midnight 200CC, three 8V Rolls batteries, Schneider Conext 4024 inverter (workshop)
- 621 Discussion Forums/Café
