Amazon is now peddling a 100 watt system...
softdown
softdown Solar Expert Posts: 4,052 ✭✭✭✭
4.1 stars? Not bad considering all the possible mistakes that purchasers are likely to make. Would be nice for camping etc.
https://www.amazon.com/dp/B06XWL79L7?ref_=pfb_53h352c6h1413kf52h13m8d05f6c&tag=hydfbook0e-20&ascsubtag=pfb-P11-V01-O3-rqx99r-RR71TD
  • Horsefly
    Let me introduce you to Fakespot.com.  Amazon and it's accompanying review database have become such a huge force, there is now a undercurrent market to do "fake" reviews and ratings. Fakespot uses an AI engine to look at the reviews and make a qualitative judgement as to the overall trustworthiness of those reviews. In this case, lots of them are considered fake.
    https://www.fakespot.com/product/hqst-100-watt-12volt-off-grid-polycrystalline-portable-foldable-solar-panel-suitcase-with-charge-controller
  • softdown
    Fakespot seems pretty cool. Soon the spoofers will be able to fool Fakespot though, this will likely be cat and mouse.
    "Our engine has profiled the reviewer patterns and has determined that there is minimal deception involved."
    A huge problem with reviews is that they are done quickly after the purchase. It would be interesting to find what the consumer thinks a few years later.
    I grew up with unlimited lifetime warranties....some of them transferable. 30 days is pretty common now. It can take me 30 days to unwrap a package. I go the post office every two weeks.
  • oil pan 4
    Or could be the people have no idea hat they are buying.
    IMO a decent charge controller should cost most of the  $200, because with something that small you will need to have MPPT.
    Pretty much totally disagree, there is no reason to spend money on a MPPT type charge controller to gain maybe 10%, particularly on a 100 watt 12 volt nominal panel....
    FWIW - This is NOT being sold by Amazon, It is in Amazon's market place and they will have to follow Amazon's rules, and you will have Amazon backing it up as it's fulfilled by Amazon, but it is being sold by HQSTSolar
    There's a clue where it says  "Sold by HQSTSolar and Fulfilled by Amazon."
  • Estragon
    It really depends on the applcation. IMHO, pwm makes more sense where panel(s) will be close to the controller and/or wired in parallel. In applications where an array is further away, higher voltage series wiring and mppt makes more sense. Use the right tool for the job.
    Okay, in this application a single 100watt panel (or a wired pair) with a Vmp of 17.8. An MPPT charge controller has NO part in the discussion.
  • Estragon
    True.
