Morningstar Suresine
Saggys
Solar Expert Posts: 189 ✭✭✭
For those that have one, can the Suresine power a 750 watt toaster? I know it is only rated at 600 watt surge, but a toaster is a resistive load.
The Sure sine is rated at 300W, the 750W toaster will immediately overload it, probably blowing the fuses, the surge rating is a momentary rating not continuous, to allow for initial inrush of a motor for example.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I thought they had a 20 minute 600 watt surge rating? Looks like a bigger inverter or a smaller toaster. Really like the Suresines small self consumption of power, hard to beat on a small system.
Peak power rating 600W for 10 minutes at 25°C, after which derating applies, quite impressive for a small inverter without a fan, but still too small.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I doubt it will run, but I don't think it will hurt to try. A couple of times someone has plugged a too-big load in while running the small inverter at the cabin. The MS squawks and disconnects, but isn't damaged. There may be an ultimate limit to the size of overload it can deal with, but I haven't found it yet.
IIRC, the fuse will blow on a DC polarity reversed connection, not overload.Off-grid.
Not too many options for a low power toaster or single slice toaster.
Saggys said:For those that have one, can the Suresine power a 750 watt toaster?Paul
> @ILFE said:
> Nope. Nada. Won't happen.
Thanks for the info.
Plus Minus Zero makes a single slice toaster with mixed reviews. It is made in Japan and rated 100 volts 500 watts. Should be 600 watts at 120 volts. -
Saggys said:Not too many options for a low power toaster or single slice toaster.Paul
ILFE said:Toast your bread over an open campfire, in a cast iron skillet. It will turn out better than by electricity anyway.
Why not get a bigger inverter for $100 more? I bought a Xantrex Prowatt SW2000 (1800W continuous) inverter for $325. It'll easily run your toaster, plus many other things. Just be sure to use the recommended 4/0 cable, and enough batteries to keep up with the demand.
This is for our bunkhouse and only needs to run 3 LED lights, TV, DVD and phone chargers.(and hopefully a toaster) The system consists of 2-80 watt panels and 2 golf cart batteries with a msw 800 watt Statpower and a 30 amp PWM charge controller.
I want to upgrade the inverter and charge controller to the Morningstar suresine and sunsaver mppt. I have a 2000 watt exceltech I could use but it consumes 20 watts at idle. -
Why not turn the big inverter on to make toast (and off when the toast is done), and use the small one for eveything else?Off-grid.
Saggys said:This is for our bunkhouse and only needs to run 3 LED lights, TV, DVD and phone chargers.(and hopefully a toaster) The system consists of 2-80 watt panels and 2 golf cart batteries with a msw 800 watt Statpower and a 30 amp PWM charge controller.
I want to upgrade the inverter and charge controller to the Morningstar suresine and sunsaver mppt. I have a 2000 watt exceltech I could use but it consumes 20 watts at idle.Paul -
Saggys said:-snip- I have a 2000 watt exceltech I could use but it consumes 20 watts at idle.
I think the suggestion to use the Suresine most of the time, and your other inverter for toast (and other brief but heavy loads) was a good one. Go ahead an hardwire both to your battery bank. Only power up the beast when needed, off otherwise. A remote on/off switch might help the situation if the inverter isn't near where the toaster is used. Not sure if your big inverter has that capability, but it's easy enough to open it up, and add a couple of wires to the existing (low voltage) front panel switch, and connect them to a remote cable/switch.
Weekend use only, has been working fine, plenty of time to charge during the week. You are correct 10 amp max into 215 ah is greater than C20. Running two inverters would work, but I would probably use the grill first, less hassle. I think I will go without toast in the bunkhouse.
Thanks for your replies. -
Nice write up and test on various inverters, thanks for the link.
- 224 Forum & Website
- 617 Discussion Forums/Café
