Generator to MPPT
Starmoral
Registered Users Posts: 13 ✭✭
I have generator rated 1500W , 24v so I m thinking hooking it directly to 80A MPPT and to 6Kw battery bank. I know it’s been discussed why can and why can’t be done this way,but I wanna know does anyone here actually tried to do something similar? Of course I would like to hear more opinions why this can’t or can work. And what would be best option to implement this generator into my off grid system.
So you want to hook a generator to a charge controller?
I thought they were only compatible with DC current.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year. -
Isn’t that on picture bridge rectifier?
What is the nominal voltage of the 6kw bank? 24v?
Is the output of the generator 24vac? Recified to dc?Off-grid.
Batteries I just ordered they will arrive coming days , but yes that’s the plan, 24.
I guess it is rectified to dc? Although I can measure ac too on multimeter when I rotate it. What do you think? Here is picture -
Among other problems, most mppt charge controllers buck higher voltage dc current down to battery charging current. A 24v nominal bank will likely want ~29v absorb charging voltage. An mppt controller would need at least ~ 45v or so.Off-grid.
Well, yes, but with no load voltage goes up to 40V. So what would you suggest for this rating ?
Also is that means that with 12v should work in theory ?
I think what you want is a good voltage regulator, not an mppt charge controller. They would be easier to find for 12v, but I think they're available for 24v.Off-grid.
You mean , generator -rectifier- voltage controller - charge controller -battery ?
The regulator is instead of the controller.Off-grid.
Point some links&examples. What should be power rating of regulator ?regarding rectifier 30A 1000W I have
You could start with www.balmar.net
They make high output alternators and 24v regulators for them.Off-grid.
A generator with a bridge rectifier would be in essence a DC power supply, the output however would not be a smooth DC such as a PV panel, an electrolytic capacitor would smooth the output, which could be used as an input to a MPPT controller, at least according to Morningstar. My advice would be to ask the manufacturer of the controller you have, if this is possible with your particular controller. See question 3, using a power supply as a substitute for PV panel in the link below.
http://support.morningstarcorp.com/faq/
Edit, the open circuit voltage may be 40V but the load voltage will drop, to charge a 24V nominal battery over 30V would be required, preferably higher, this would be a very Inefficient means of charging by the way, as ~80% of the fuel is wasted as heat, the internal combustion engine is not particularly efficient.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
A generator with only a simple rectifier (4 diode bridge) will have too much Ripple for most charge controllers to manage.
A MPPT controller expects to see "soft" solar panels, and searches electronically for the MPPT setpoint, and relies on adjusting the PV voltage to control charging. A generator will never behave like PV panels.
Some MPPT controllers have preset curves for Hydro or Wind generation, but they also rely on large voltage clippers and loads to help regulate the power, and that would waste fuel on a generator. Also most turbine gear is multi-phase AC with much less ripple to contend with.
In short, I don't think you will be happy
Thank you, so clearly says on morning star website that MPPT have no issue with this kind of DC. Anyway i would say all of you are talking from theoretical side, no one actually tried to do such thing? So i m gonna try and see ,only way i can know what is going on. Also it is cool idea with electrolytic capacitor as you mentioned ,i will try that too. I let you know everyone how does it go.mcgivor said:A generator with a bridge rectifier would be in essence a DC power supply, the output however would not be a smooth DC such as a PV panel, an electrolytic capacitor would smooth the output, which could be used as an input to a MPPT controller, at least according to Morningstar. My advice would be to ask the manufacturer of the controller you have, if this is possible with your particular controller. See question 3, using a power supply as a substitute for PV panel in the link below.
P.S. generator will be powered by pedaling. -
Ok, you are talking about a peddle powered generator/alternator which is probably ~100-200 Watts maximum. A small MPPT charge controller (for example: 15 amps * 14.5 volts charging ~218 Watts) would be more than large enough for your needs (assuming a single person as a power source).
