Solar inverter need help with EAST / WEST facing string on a single inverter...
Chan
Registered Users Posts: 45 ✭✭
I have this inverter where in i have 2 strings each facing east and the other is west,
the problems I see as of now is that the inverter will get both AMPeres and balance everything out, this makes the output smaller than expected, as I check the manual of the said inverter, it has a 2 mppt, based on the SOLAX website "| http://www.solaxpower.com/en/x1-boost-3/ "
eg, 1 string will have 2.5kw while the 1 string has a 1.5kw, this will bring down the amp of the said inverter down...
Is this normal for all inverter to balance the ?
It will be lower, but over a greater time span. For a grid tied system, East and west facing arrays have no advantage that I can see.
the problem im seeing right now is that the inverter is trying to balance amp and the spec is that its a dual mppt... probably some setting is needed....
There is a string sizing tool on the website, See if your configuration is valid. You need to make an account and login.
http://design.solaxcn.com:6180/design/
4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
yup.. everything is in order actually...
anyway. im trying to get hold on their customer service....
Probably a good move. I am not familiar with it, and have only heard of one other in Australia.
