Inverter won't start
                    trAxe3
                    Registered Users Posts: 3 ✭
                    Hi there. Recently I installed a solar water pump system, model SI-10 VEICHI . The entire day it works normally..but in the morning it won't renew it's activity. In the night it turns off, in the morning it should turn on automatically..so it does, but frequency 0.00 Hz is displayed and it won't start inverting). All settings are by default and wires conected properly.
Any ideas? Thanks!
      Any ideas? Thanks!
            Is it connected to a battery, and if so, what is the size and state of charge?Off-grid.
            It does not have a battery or other storage devices. As I understood, it should turn on by itself when there is enough solar energy. The LED light on the "FWD" button should be always on, but after night break it is off and 0.00 Hz is shown.
My father asked me to find any solutions to this problem and i don't have knowledge in electrical engineering
            A link to the mfg's web page or manual would be helpful
            http://veichielec.com/1-1-solar-pumping-inverter/203087
Search engines are wonderful things. -
            @solray - so do you have the solution?Off-grid.
            @trAxe3 - what is the configuration of the solar input, and the pump?Off-grid.
            @Estragon all settings are by default. Yesterday we tried to reset to factory values, but still no improvements.
Here is the manual of the inverter http://en3img.allhaving.com//upload/2972/o/1_1_6_tension_control_frequency_inverter_2.pdf
This" inverter" appears to be a variable frequency drive, the manual has no mention of solar input, that I saw at least, it shows an AC input, which has me thinking there is more to the system. How is the solar connected? DC in to the inverter?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
 - 232 Forum & Website
