Pump powered by an invertor not working. Why
allotmentman1
Registered Users Posts: 8 ✭✭
I Have bought a Ring 500 watt invertor to run a pond pump rated at 65 watts power. The pump does not work from the invertor but works plugged into the mains power. Any ideas why?
Do other loads work with the inverter, try a resistive load if possible, incandescent lamp, the modified sine wave may have a conflict with the pump, I'm assuming it's modified sine wave after a brief search, no mention of pure sine wave, this usually means modified Can you confirm?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Yes modified wave. The manufacturer has recommended a pure sine wave should have no problem. The modified wave ran a electric drill and a sander ok but not the pump.
That's what I suspected, some motors are temperamental with a square waveform.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Ive purchased a soft start 300watt pure sine wave inverter with peak power of 600watts, Hoping that will be enough to cover the start up load of my 50watt pump
Let us know how it works out.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Would be interesting to know exactly why the pump doesn't work. My guess - that this particular MSW waveform has a lower peak voltage.
This is a good explanation of how some MSW inverters have a hard to predict peak voltage (they vary the pulse width based on battery voltage).
https://www.homepower.com/ac-output-wave-forms
Difficult to say without details for the pump or the inverter, the pump could be low voltage DC using a switching transformer, which do not like square waveform of any kind, but again, just speculation.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
The reason it will not work is it uses an incompatible waveform.
Thanks guys for comments. Will try and see when I get it. Buying this stuff on ebay in UK all made in china and very little specification on any paperwork, so cant give you more detailed info on pump or inverter.
- 611 Discussion Forums/Café
