Different panel
peterjack
Registered Users Posts: 1 ✭
My question regards using different 12V panels with others. I have the
45w Harbor Freight set up and was given two Sharp 75w panels. Can I put
them all together and if so, should I use an MPPT controller or will a
Morningstar 20 be OK?
You cannot mix disparate panels using an MPPT charge controller, period. If you had one, and "added" the two 75 watt panels to your current three 15 watt panels, you'd gain 30 watts worth of power. Your two 75 watt panels would become two 15 watt panels, to match your three current 15 watt panels. Any PWM charge controller, especially a Morningstar (my favorite portable PWM controller) will work great, as long as it can handle the total combined amperage, which your Morningstar 20 amp can with ease.. Good thing you already had one, huh?
Oh, and welcome to the forum.
DoD= depth of discharge= amount removed from that battery SoC= state of charge= amount remaining in that batterySo, 0% DoD= 100% SoC, 25% DoD= 75% SoC, 50% DoD= 50% SoC, 75% DoD= 25% SoC, 100% DoD= 0% SoCA/C= air conditioning AC= alternating current (what comes from the outlets in your home) DC= direct current (what batteries & solar panels use) -
I am having difficulty parsing this argument:myocardia said:You cannot mix disparate panels using an MPPT charge controller, period. If you had one, and "added" the two 75 watt panels to your current three 15 watt panels, you'd gain 30 watts worth of power. Your two 75 watt panels would become two 15 watt panels, to match your three current 15 watt panels.
1. it can't be done
2. when done, it doesn't work very well.
Related: there is a neat series of YT videos where AltE tested various configurations of mismatched panels.
Paralleling 12V nominal panels with different power output using a PWM controller is not a problem, MPPT is a different story, 195W with a 20A controller (PWM ) should be fine.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Panels can easily be added in series or parallel.
To add in series, the AMPS must match within 10% of each other. The array amps will be limited to the lowest amp panel.
To add in parallel, the Volts must match within 10% of each other. The array voltage will the the voltage of the lowest panel.
LMAO, yeah my first sentence would have been better elucidated had it instead been, "You should not mix disparate panels, period." I would think it fairly indisputable that the OP got the gist, though.fratermus said:
1. it can't be done
