Lestronic 24 volt battery charger Model 13110 25amp
mryimmers
Solar Expert Posts: 117 ✭✭✭
I'm looking at a battery charger like this one http://www.ebay.com/itm/LESTRONIC-II-24LC25-8ET-24-VOLT-BATTERY-CHARGER-golf-cart-/222572742631?hash=item33d25e87e7:g:ZY8AAOSwz71ZXmgW&vxp=mtr is anybody using these? I would really only have it for emergencies, and not use it for long periods of time, just for some bulk charging if needed. Thanks
510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
Would be interesting to compare to this one. Less expensive and 2x the amps.
http://www.ebay.com/itm/110-120v-AC-to-24vdc-24-V-volt-DC-converter-50-amp-battery-charger-maintainer
Have used the Lestronic charger for scissor lifts, auto scrubbers and such, they seem to be robust and reliable but new price is $500 plus, there are other options, new with warranty, if you were considering the used one linked
https://www.solar-electric.com/catalogsearch/result/?q=battery+charger
No, there is one for sale locally for far less, seem like a good heavy duty charger, and ya, the new ones are $$$$$510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
