Prostar MPPT Display Blank
nickdearing88
Registered Users Posts: 100 ✭✭✭
I went to check on my system this evening and noticed my CC's display was blank. The backlight comes on upon a key press, the SOC indicator lights are one, and the system appears to be functioning normally, but no characters on the display. Battery voltage was 25.9, Array voltage was 59.1. I can't imagine what happened.
The CC display was working normally when I was outside this morning.
I figure I'll disconnect/reconnect the solar and battery inputs to reboot and see what happens but wondered if anyone has ideas.
Edit: Is there a secret key sequence to reboot the controller without being able to see the menu items?
Current system: 8-100w Renogy panels mono/poly, 2 strings of 4 panels in series - 24v 100Ah AGM Battleborn LiFePO4 batteries - Morningstar MPPT40 CC - 1500W Samlex PSW inverter
If performing a manual reboot disconnect solar first then battery, reconnect battery first then solar, you probably know this but just a reminder.FWIW1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
mcgivor said:If performing a manual reboot disconnect solar first then battery, reconnect battery first then solar, you probably know this but just a reminder.FWIW
The controller is also powering loads correctly, I tested my DC lights and small fan. Very strange.Current system: 8-100w Renogy panels mono/poly, 2 strings of 4 panels in series - 24v 100Ah AGM Battleborn LiFePO4 batteries - Morningstar MPPT40 CC - 1500W Samlex PSW inverter -
Tech support is a good option, Morningstar generally is pretty good with assistance.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Joe from Morningstar emailed me back this afternoon and suggested I remove power from the controller and reboot. I did so and the display is now back to normal.
Now I don't have to worry about sending it in for a replacement....hopefully. The unit recorded no faults in the log from yesterday or today.Current system: 8-100w Renogy panels mono/poly, 2 strings of 4 panels in series - 24v 100Ah AGM Battleborn LiFePO4 batteries - Morningstar MPPT40 CC - 1500W Samlex PSW inverter -
You might want to check if you have the latest Firmware on the Settings display screen.
v14 is currently available on the support site on the Software Tab here.
http://support.morningstarcorp.com/search/?searchterm=prostar+MPPT+Firmware
v10.0 fixed meter screen blank outs and contrast issue
Here is a link to the UMC-1 USB to Meterbus adapter which provides a PC connection to the PS-MPPT.
https://www.morningstarcorp.com/products/usb-meterbus-adapter/
This video shows how to update the firmware.
https://www.youtube.com/embed/luKLEnRjxkk
You may also want to adjust the display settings.
Also for future reference the "Reset Control" Command will reboot the controller.
From any of the Main Status Screens:
1X) Down arrow to Commands Menu
1X) Right arrow to Command Menu Select
5X) Down arrow Reset Control
2X) Right arrow to Reset and Confirm Reset
-MStar Applications EE -
MStar1 said:You might want to check if you have the latest Firmware on the Settings display screen.
I would like to purchase the EMC-1 to gain the webserver ability, can it also be used to update the firmware? I hate to just by the USB adapter to only update the firmware. I can do all necessary configuration I require using the built-in meter/display.
Thanks for the command sequence to reboot without the display working; that's what I was looking for.Current system: 8-100w Renogy panels mono/poly, 2 strings of 4 panels in series - 24v 100Ah AGM Battleborn LiFePO4 batteries - Morningstar MPPT40 CC - 1500W Samlex PSW inverter -
We are developing the ability to perform remote firmware updates with the Prostar and other products with the EMC-1. However, that feature is not yet available and I an not sure when it will be available.
The EMC-1 provides a LiveView HTML display which you can access on the LAN or the web with port forwarding. We should be posting the EMC-1 Firmware update on the website by the end of the year which will have the web service which requires only a password protected login rather than port forwarding.
- 225 Forum & Website
- 617 Discussion Forums/Café
