12v to 24v conversion advice needed
malibuskier
Registered Users Posts: 5 ✭✭
I currently have a MS2812 Single Magnum Power Center in a 12v configuration. I am interested in upgrading the inverter to a MS4024 and upgrading my system to 24v. Do I need to make any changes to the Power Center itself? From everything I can find document wise (to my understanding) it should be a simple swap of the inverters. Am I missing anything here?
Thanks,
Dave
Thanks,
Dave
What about your solar array and solar charge controller(s)? You may need to do some rewiring/reconfiguration there.
The new inverter may have a smaller max breaker size?Off-grid.
I use power center as all the 'stuff' in front of the house panel, so yes. You will need to change to a 24 volt battery bank, setup your charge controller for charging the 24 volt battery bank, and perhaps reconfigure your array to charge the 24 volt battery bank...Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
- 234 Forum & Website
