Inverter/charger not working with generator
solar_patagonia
Registered Users Posts: 4 ✭
Hello,
I'm new on solar energy. I have a house off grid in the chilean patagonia, and have the following equipment:
- 10 solar panels 250w 24v
- charger controller 60A
- 10 batteries 100AH 12
- inverter/charger 3000w (Kuhn Kgp series)
- generator Honda eu2000i
The problem is that i cant charge the batteries with the generator. The wiring was made following the manual instruction. I've tested the volts in the AC input in the inverter, and everything seems ok, but the inverter is not in "charging mode". I dont know if I have to change some configuration on the inverter or something.
I would much appreciate any help.
I would start by checking the AC frequency on both the inverter and the generator. Maybe one is at 50hz and the other at 60? The honda is likely fixed frequency. The inverter may be switchable?Off-grid.
Thanks a lot for the advice. Indeed it was a frecuency problem. I switched the inverter and now is charging the batteries without issues.
One more question... is there any chance that by modifing the frecuency of the inverter could be damage it?
Thanks again! -
I realized now that what I changed in the inverter was the range of frequency acceptable to work with. So probably my honda has a frequency less than 45 or more than 55 Hz, or is unstable.
When I bought the honda eu2000, they said that the frequency was fixed in 50 hz, considering it was a "inverter/generator".
So, what could be the problem?? I mean, now is working but I would like to know why.
The honda is brand new -
I don't think the honda's frequency should be varying by anything like that (+/- 10%). If it's set for eco mode, you could try setting it for regular. Maybe the charger is loading it faster than it can adjust?
You could also check the charger setting for max current. My eu2000 will only output ~12-13aac@120v sustained, and doesn't surge a whole lot beyond that. A 3000w inverter/charger may draw more than that in charge mode by default. Does it display ac input voltage/frequency by any chance?
I think the frequency is software controlled in inverter generators. I wonder if yours was actually set for 60hz by mistake? I don't know how this is done or if dealers have the capability to change it. You might want to ask your dealer, and let us know what they say.Off-grid.
The inverter displays 220 input and 50hz frq.
The dealer doesnt have a clue about it, and said that the generator definitely gives 50hz freq... -
The inverter probably has an acceptance, or qualification frequency range, if outside the frequency range it denies acceptance. Changing the inverter to 50 Hz, which is what I assume you did, would mean the generator is within the window of acceptance. Usually generators are set up for the frequency of the market they are sold in and the inverters have a window of acceptance, adjustable for regonal compatibility 50 or 60 Hz. To compensate for mechanical delay caused by an introduced load, which could cause a momentarily drop of frequency on a regular generator the window of acceptance may be wide, say 45 to 55Hz , Inverter generators are probably more accurate as far as output frequency is concerned, using electronics to stabilize frequency and compensate for mechanical lag. The frequency on the generator I have, a single cylinder diesel non inverter type, varies between 49 & 53 Hz depending on loads. Some digital multimeters can read frequency to verify what other indicators read, a useful tool to have. As far as causing damage to the inverter is concerned, I would think it unlikely.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 228 Forum & Website
- 618 Discussion Forums/Café
