Wind & Solar Charge Controler one battery bank
Lumisol said:Ever have to autorotate a helicopter? No?The A/C is built with a very large margin of efficiency and it will not loose enough to even be worth mentioning.Quite possible. The efficiency loss may be low; of course, in that case harvested energy will be low as well.An excellent example! It will reduce the efficiency a tiny bit because your hand is small. Now, if you mount a wind turbine on the top of an EV, and try to use that to charge the car's battery, you will ALWAYS lose more to drag than you gain in power. Same principle.
Like putting a hand out the car widow at 55 mph will reduce efficiency of the car.
bill von novak said:Lumisol said:Ever have to autorotate a helicopter? No?An excellent example! It will reduce the efficiency a tiny bit because your hand is small. Now, if you mount a wind turbine on the top of an EV, and try to use that to charge the car's battery, you will ALWAYS lose more to drag than you gain in power. Same principle.
It's not even close, the A/C does not move down the road at 55 mph. If it does, jump! -
Hmmm... does this forum have an 'ignore' button for those we wish to ignore?
Oh come-on... We have a product that does not have any energy recovery claims other than a blinking LED on a small GT inverter.
And you did ask about our experiences and you had two pilots (one w/ helicopter experience and one fixed wing) and at least one engineer (me) replying to your questions.
Anybody has actual/claimed energy recovery for a "typical" installation of this device? Then we don't have to guess/estimate/scale from other data sources.
Here is paper using HAWT and combination of computer+measurements from Department of Mechanical Engineering, Faculty of Engineering, University of Malaya:Design and Experimental Analysis of an Exhaust Air Energy Recovery ...
For the actual size of a cooling tower with a 2.4 m outlet diameterA quick read through the paper is a bit confusing... There are no actual power "results" just Cp (efficiency?) that indicate 5% to 13% recovery...
and powered by a 7.5 kW fan motor, it was estimated that a system with two VAWTs
(side-by-side) can generate 1 kW of power which is equivalent to 13% of energy recovery.
It is interesting that the exhaust fan had (on average) a small reduction in electrical consumption and an increase in air flow through the condenser--That is counter intuitive--A centrifugal fan generally decreases energy usage when the mass of air through the fan is reduced.
Anyway, another source that ~10% exhaust fan energy recovery is possible... Not a lot more than that though.
Honestly I can't think why such a trivial subject has become a serious debate, I could add by asking why competitive swimmers shave their bodies, because each hair adds to frictional loss? But why? Send an email to the producer of this product and ask for some hard data, my thinking is there is none, but they will gladly take your $599 or whatever it costs, not even interested in looking up the price, snake oil comes to mind....However I digress.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
mcgivor said:Honestly I can't think why such a trivial subject has become a serious debate, I could add by asking why competitive swimmers shave their bodies, because each hair adds to frictional loss? But why? Send an email to the producer of this product and ask for some hard data, my thinking is there is none, but they will gladly take your $599 or whatever it costs, not even interested in looking up the price, snake oil comes to mind....However I digress.
I cannot imagine why anyone would want to talk a person out of something they want to try for fun. -
BB. said:Oh come-on... We have a product that does not have any energy recovery claims other than a blinking LED on a small GT inverter.
Saying it isn't worth it is not up to you or me, it's whether it's worth it to them that counts. -
Personally, I find the theoretical discussion interesting. If the person goes ahead and tries it, I'd also be interested in whatever empirical data they might be able to share, whether it works or not.
I've actually considered creating a "failed" trial database because databases tend to be populated only by successful trials. I probably learn more from failures than successes.Off-grid.
Lumisol said:Hmmm... does this forum have an 'ignore' button for those we wish to ignore?
That would be nice. I know where I'd start.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
Yep, same here.
Well, because this is a $599 product with no specifications that is being advertised as an energy saving device--Seen too many of those (and ones that violate the laws of thermodynamics) to be anything else other than wary of the product.
I never said don't try it or don't experiment. I just asked how much energy it would recover and researched others who have done similar projects and reported their results--As well as estimating where the major losses could be.
Lumisol said:Why would it matter if they recover 1/10 of a cent over a 50 year period, if they want to play around and learn in the process, let them.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
