my wind turbine
fantom007gr
fantom007gr Registered Users Posts: 20 ✭✭
  • fantom007gr
    hellow  everybody from athens greece.
  • mvas
    mvas Registered Users Posts: 395 ✭✭✭
    edited May 2017 #3
    Very nice!
    With Wind Turbines the rule is ... The higher, the better.
    Can you raise the turbine higher, to get above the roof's turbulence ?
    Some questions ...
    Diameter of the rotor = ?
    # of Kilowatt-Hours it generates per Year = ?
    # of Kilowatt-Hours it generated on its best Day = ?
    Are you charging a battery bank?
  • fantom007gr
  • fantom007gr
    this is what  changes i did today.some diferent arangement.
  • fantom007gr
    diameter of rotor is 120 cm
  • fantom007gr
    the generator is 1000w ,from usa but it never produced this power.
  • fantom007gr
    140 wh the batery.
  • mvas
    edited May 2017 #9
    It is best if the Wind Turbine is 10 meters higher than the top of the nearest structure.
    I see that you have changed from one tail, to two tails.
    Did you have a problem keeping the blades pointed into the wind?
    Does the wind blow at a constant 6+ m/s, for many hours per day?
  • aminaelis
    aminaelis Registered Users Posts: 14 ✭✭
    Great job! Looks awesome. Are you satisfied with the outcome? I suppose Athens are not the windiest location...  :D
  • fantom007gr
  • fantom007gr
    one of the tries i attemted, here with my old washing machine.
  • fantom007gr
  • fantom007gr
    some new projects,and with the pulley i h
  • fantom007gr
  • fantom007gr
    with the pulley i have mutch better performance
    How well does it point into the wind? The length of the arm to the "tails" seems pretty short (they are mostly to the "side" of the pivot point, not very much to the "rear" of the pivot/yaw bearing).
  • fantom007gr
    hellow bill,thanks for your notice my friend,well the wind turbine is staying against the wind but also you can see looking around many times left and write ,so it misses a lot of power,yes it does twist alot in high winds,but in the other hand is like furling .thats why i am building  the wawt now ,the vertical wind turbine.
    Looks like you are building up an axial flux generator ?
  • fantom007gr
    yes mike,my next plan ,but it takes me a lot of time which i dont have ,and it looks that it will take time.
  • fantom007gr
    i am in the time that i need to test the rpm of the constaction with the wings i have so i will after fix the coils .i will post pictures.
