Power Inverter to AC breaker box connection. Please help!
KNLsolar
KNLsolar Registered Users Posts: 18 ✭✭
Trying to find out the correct way to hook my AC output of my power inverter to an AC breaker box. From what I have seen you need a special output on ur inverter. Any knowledge would be appreciated!!
    ??  My 1,500W inverter has a spot to connect some 10 AWG house wire and screws to clamp down and then I needed a strain relief device as used in any 'octagon' box...  hth
  • KNLsolar
    What about grounding? The inverter and AC breaker box can't be on the same ground can they?
  • Raj174
    The inverter and it's AC sub panel have a common ground.
  • Estragon
    What make/model of inverter? The manual should cover grounding and neutral bonding, it's not always the same for every inverter.
