My charge controller was putting out high voltage.
bc buck
bc buck Registered Users Posts: 59 ✭✭
I noticed when opening cabin early AM after being gone all week the prostar mppt was putting 15.2 volts at 2A to the battery bank. Battery's showed 100% full. Charger setup absorp14.7v, float 13.5v. Was blinking as if in float stage. Controller seemed to work fine rest of weekend. Should I try to contact manufacturer for defective charger?
    Do you have it setup for auto equalizing?
    Does it have a Temp sensor built in or remote?  Cold = higher volts while charging...
  • bc buck
    Yes the remote temp was 32F.
  • Estragon
    You could check temp compensation setting in controller vs battery recommended. Sounds like a high comp for that temp - I would have thought <1v higher. Maybe the CC had just come off absorb and voltage hadn't settled to float?
