MicroSolar 24V 3000W (Peak 6000W) Pure Sine Wave Inverter [INV-3000PS] good?
Fabian
Fabian Registered Users Posts: 137 ✭✭
Can anyone tell me if this chinese inverter is a good buy.
I sent a seller some questions regarding it and i haven't got back a reply so i am posting the questions hoping to get some response.
The unit is rated up to 30v input.
I saw on amazon where a seller said this unit cuts out when the solar panel voltage regulator goes through its equalization mode (higher voltage) during cold ambient temperatures because it inaccurately calibrated on the high voltage side by the manufacturer.  So I want to know if is when it reaches 30v it cuts off or when it goes over that voltage? Or is it that because it is inaccurately calibrated the 30v max input with +/- maybe actually 29v or even less?
The next question is that a seller complained that whenever it goes into the low battery alarm stage and even thou the battery voltage might rise up back to the required level there is no output unless you turn it off and turn it on again.
Is this issue cause from the fact that it is a momentary push button start inverter?
  • mcgivor
    Do yourself a favor and look at something a little better, 30v maximum is low for a 24V inverter, should be at least 32V, low voltage cutout should be auto reset, go with a name brand, Samlex or Cotek in the middle, they are good choices and they have a warranty which you at least have a chance of redeeming.
    The way a "typical" inverter manually resets from low battery voltage is you have to turn off the main breaker/DC input switch to the AC inverter.
    Do you need that large of AC inverter? 3,000 Watts on a 24 volt battery bank requires some pretty heavy (and short cable) wiring. For a "full load":
    • 3,000 Watts * 1/0.85 AC inverter eff * 1/21.0 volts battery cutoff = 168 Amps max continuous
    That is some pretty serious current and draw from a battery bank. You are right on the edge of justifying a 48 VDC AC inverter.
  • oil pan 4
    edited March 2017 #4
    Sounds like typically cheap Chinese made junk.
    I have a 12v samlex and it works great.
  • mathias
    mathias Registered Users Posts: 31 ✭✭
    Hi,
    I have no idea if this is good or bad stuff, but the comment like go for a Cotek, well... I had a 48v which cut at 60v, and now a 12v which cuts at 15v. So i guess a 24v will cut at 30v...
    As for the warranty...
    You have to look at the specs closely. Samlex has two different product lines. One has higher DC input working voltage vs the other.
  • mcgivor
    mathias said:
    Hi,
    The older Cotek models were 60V OVP, the newer ones are 62- 66V, depending on product line.
  • mathias
    Ok, glad they did this change, so much for me !
