getting ready
TBob
TBob Registered Users Posts: 0
Hi,
I am getting my off-grid home set up and will have a 48 volt system
I have 10 320 watt 24 volt panels, an Outback FlexMax 80, and 8 L16HC XC2 (420ah) batteries for a 48 volt bank to start with. The plan is to double this next year.
My lighting runs on a separate 12 volt system which is already in place.
The questions I have are:
I need a circuit breaker installed I assume.
What do I need for a charger/inverter to do the following.
I need to feed a 120 volt breaker box from the 48 volt system, and am unsure what type of inverter I will need to do this. There is zero grid power to the property, so that is not a concern...there never will be as it is so remote the cost is prohibitive.
What am I missing?
Thank you
  • oil pan 4
    You are missing a backup generator and battery charger.
    In general batteries age together, I would not add new batteries to 1 year old batteries.
    If you only have 120 volt then just about any 48 volt to 120 volt inverter would be fine.
    There are assorted fuses or breakers needed. Midnite makes an Epanel that has most of them all in one place. Some Epanels allow for mounting types of inverters on the door making for a compact system, or generic ones allow for mounting beside the inverter.
    https://www.solar-electric.com/marine-rv/installation-supplies/midnite-solar-e-panels.html
    In addition you will want a combiner box if you have more than 2 strings of solar panels, this allows for fuses or breakers for each string on panels.
    A generator is often nice for backup, I don't use one, but most have some sort of back up energy.
    If you already have purchased the batteries, it would be good to charge them every  month or so...
  • Estragon
    If using an Outback charge controller, there is something to be said for using an Outback inverter/charger so you can share mate display/control. An epanel definitely helps with wiring, breakers, etc.
    I would second the thought on not mixing new and old batteries.
    If you have no 240V loads (well pump ?)  then any 120V pure sine inverter that meets your max power needs would work.  Check the standby self consumption,  that can amount to a fair amount of "lost power" in 24 hours
