enviromech2: Two strings on GT Inverter with different voltages
Posts: 93 admin
This discussion was created from comments split from: Two Strings in Parallel with Unequal String Voltages.
two strings of different voltages
my new array installed today which i havent paid for has two different voltages 15 volts different 12 panels per string 24 panels is that ok or normal i think thats outside manufacters tolerances help any ideas -
Envriomech2, I have made a thread/discussion for your questions. This will keep things focused on your needs.
Can you tell us a bit more about your system? What GT inverter, what Vmp/Imp solar panels you have, etc.?
thanks in australia 24 panels canadian solar 270 watt inverter sunny tripower sma three phase dual mppt input
roof shallow pitch north face no shade 30 to 40 degrees celcius thats hot in farenheight
just fittted by company not grid tied yet thats today
15 volts diference on sma screen betweeen the two srtings
company says as one string was on roof for 4 hours and second string only two hours string one heated up more which reduced output
this is possable as cooling panels in hot climates can give a lot more power ive done it years ago cant remember figure but was maybe 10to 20% built my first pv system in 1984
mr chan says heat max accounts for 4%
panel manufacters spec is 5 w over 270 watt
during install no commisioning was done on each panel
and as comissioning says go home come back next day when full sun fresh minds and clear heads
appriciate your thoughts
thankyou ric downunder -
fixed!
even voltages
panels that wake up in the sun together lose efficiencey due to heat build up at the same rate
panels still in the box for two hours longer ie cooler work better till they heat up
the company guru was correct although the installer had not seen before
the usa solar panel commisioning hand book while doesnt allude to this phernomon is still very wise and a good short read
thankyou for this forum
collected 27k from 12pm on ie half a day
i think i may have a bit more western orrientation happening
as we have the honor of the dearest power in the country and third highest world wide soon well be number one!
looking at home battery now
hoping goverment will subsdise home micro power station battey packs allowing home owners to feed back into own failing grid system
which is damaged beyound repair by the greenies
the govt subed 1000 tesla 1 walls in june last year
grid is at crisis point now and much disscusion happening
yours ric downunder
now were,s my model s lol
Keep in mind that to 99.99% of the people in the world, you are one of the greenies.looking at home battery now
lol i know warm fuzzies to all
but i think before stamping out the brown coal fire that runs thier soy latie machine they should have at least checked if an alternative was running
deep pressure water storage looks interesting storage idea
ta ric -
"deep pressure water storage" is what ? Water cannot be pressurized like air, it does not compress. You build pressure from the weight of the water column height.
concrete vessels on sea bed water removedwith pumps at times of cheap power then refillled trough turbines when power is needed scotland maybe harsh enviroment
its going to be ok Elons offered us 100 mgwh in 100 days or its free
go elon
- 225 Forum & Website
- 617 Discussion Forums/Café
