Trying to set up a system
jtroughton
Registered Users Posts: 1 ✭
I am trying to figure out a solar set-up for my outdoor Pool Pump. It is rated at 110/115 Volts, 3.5 amps. Would it be feasible to try and set up a system so that I could run the pump for 18 hours a day or more, or is that asking quite a bit for a system set-up? Thanks.
It is doable. 7KWhr a day. You'd be looking at a ~28KWh battery bank for 2-day autonomy and a 4KW solar power system for charging (that will depend on location, exposure etc). Call it about $30K with battery changes ($8K) every five years or so.jtroughton said:I am trying to figure out a solar set-up for my outdoor Pool Pump. It is rated at 110/115 Volts, 3.5 amps. Would it be feasible to try and set up a system so that I could run the pump for 18 hours a day or more, or is that asking quite a bit for a system set-up? Thanks.
if it's a pool pump with grid power, you are better of with
a) buying a high efficiency 2 speed pump (3 year payback)
b) installing Grod-Tie solar to offset the pumps usage. (10-15 year payback)
