Buying a used solar panel ?
bc buck
bc buck Registered Users Posts: 59 ✭✭
Talked to a guy wanting to sell a Sharp 235w panel for a $100. What should I look for other than cracks in glass and voltage output.
  • mcgivor
    If I were to consider a used panel these are the things I would check, open circuit voltage and short circuit current and determine if there's a use for it, for example if it a 60 cell panel, it cannot be used with a PWM controller. The glass won't crack, it will only turn to cubes if broken, my opinion would be to consider new panels over used, you might be able to get close to that price with new, sometimes buying used is a false economy.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,172 ✭✭✭✭✭
    Damage to the back sheet.  Any discoloration in the cells and cell interconnect tabbing. Most solar panels (including Sharp) use tempered glass and when broken will shatter into a "million pieces" so if not shattered the glass should be fine.
    Voltage output isn't a full indication of a working panel. You want to see the short circuit amperage and is so equipped  test the panel under load.
    I think you had some Kyrocera 12 volt panels? This would not be compatible with those.
    Not really a great price, other than you don't have to worry about shipping. We're seeing prices for new in this neighborhood.
  • bc buck
    Yes, I installed three Kyocera KD145sx-ufs in series. When I replaced my battery bank I increased the AH to 430. Could use a little more watts if I could get a good deal and save on shipping. The Morningstar PS-MPPT-40 said it could be over watt in panels as long as did not go over Voc of 120 DC. The three Kyrocera total Voc=66.9. Was thinking if added Sharp in series 37 Voc would = total Voc of 103.9. Does this sound  like it would work. Thanks
    They won't work properly on the same charge controller. You would want to put them on separate charge controllers. Other wise in a single string the output would be limited to the amperage of the Kyrocera panels, so you would get less total effective power (wattage) from them.
  • bc buck
    Thanks, il need to start looking around for another Kyrocera 145.
