Watt meter help
littleharbor2
Does anybody else have one of these in use. I have 3 of them that have been kicking around for a while. They don't have any instructions and all the overseas venders are of no help. There are a red and black wires for line and load and a small port. I have seen these pictured in a discussion here in the past. Seems the port would accept a modular plug wired to a shunt maybe, but they aren't sold with any such modular plug nor instructions.
  • Raj174
    Found this youtube, it appears to have a 100 amp shunt built in.
    https://www.youtube.com/watch?v=LUuPvfDmSZM
    You can read about a similar meter here:
    http://www.rc-electronics-usa.com/electrical-test-equipment.html
  • littleharbor2
    Thank you both. I will go through the text and video.
  • dennis461
    dennis461 Registered Users Posts: 109 ✭✭✭
    edited February 2017 #5
    If it is similar to others, it is not rated for 100 AMPs continuous.
    http://www.rc-cars-planes.com/docs/wu100v2_user_manual.pdf
    Camden County, NJ, USA
    19 SW285 panels
    SE5000 inverter
    grid tied
    I would suggest that most of these types of devices are way over spec'ed... 100 Amps for a second? Probably closer to 15-20 amps max continuous (from the typical wiring size).
  • littleharbor2
    I made the connection between CC, (source) and Battery (load) trying to measure charging of my battery and the unit wouldn't even light up. Maybe this is a bad unit.
     At least I have found out the port is for aux. power when measuring small voltage sources.
