Is this going to work?
JesperEybye
Registered Users Posts: 2 ✭
Will 40 of these cells be enough to power a 12v off grid battery system, even on a cloudy day?
Maybe, maybe not ... it all depends upon how cloudy it is and how much power you need.
Cloudy like, it isn't totally dark, but the sun isn't shining directly on the panels either.
I need 14 volt or so to charge the 12v battery
JesperEybye said:Cloudy like, it isn't totally dark, but the sun isn't shining directly on the panels either.
Even under room light they will likely produce 14 volts, but next to 0 amps/current.Voltage is NOT a measure of power, wattage is a measure of power, watt= amps x volts.
We would want a lot more info; size and type of battery, actual loads (this isn't going to run your house)
It would have to be a pretty small battery. You might get a couple of amps at ~14v to charge it with thin cloud.Off-grid.
Nominally, 4.1 amps @ 18 volts would require 36 cells. The "standard" 12 volt battery bank charging panel configuration.
For a lead acid battery bank, we suggest 5% to 13% nominal rate of charge (20 Hour Rate). 5% can be OK for weekend/emergency use. 10%+ rate of charge is better for full time off grid:- 4.1 amps * 1/0.05 rate of charge = 82 Amp*Hour @ 12 volt battery bank maximum
- 4.1 amps * 1/0.10 rate of charge = 41 Amp*Hour @ 12 volt battery bank nominal
- 4.1 amps * 1/0.13 rate of charge = 31.5 Amp*Hour @ 12 volt battery bank minimum
- 18 volts * 4.1 amps = 74 Wmp
- 74 watts * 0.61 DC off grid system eff * 4.0 hours of sun = 181 Watt*Hours per day
- 181 WH per day / 12 volts = 15 AH per day
http://fieldlines.com/board/index.ph...,144982.0.html
http://fieldlines.com/board/index.ph...,144995.0.html
http://fieldlines.com/board/index.ph...,145004.0.html
And here is what can happen if the panels are built "wrong":
Panel Fire Question
My suggestion is to buy good quality factory panels (glass front, mono or poly crystalline cells). It is very difficult to build "good" panels from raw cells--And many of the raw cells are actually factory rejects from panel manufactures.
Panels used to be $10-$30 per Watt (10-20+ years ago). You can buy a pallet of panels today for around $1-$2 per watt (plus shipping-which may not be cheap). Spend your time & money on robust design (first) and good quality equipment.
Today on a cloudy day, my 5Kw of pv produced about 2Kwh. If you don't have bright direct sun, you don't get much power.
And it looks like you have wafers, and are going to build a panel. 6 months later, you are likely to have 0 watts.
How many Amp-Hours is this "12 volt off-grid battery system" ?
Your plan is ... 40 cells x 0.5 volts each = 20 Volts x 4.1 amps = 80 Watts.
80 Watts is a very small solar panel.
80 Watts / 15 Volts (charging) = 5 Amps into the battery with MPPT Charger.
So, maybe you use a single 12V 100AH battery with 50% DOD max draw down.
That is OK for LED Lights and very small loads, only.
On a cloudy day you might generate only 2 Amps ( 32 Watts / 15 Volts )
That is very low, but yes it is do-able.
Q1) What size battery do you need for "off-grid" ?
Q2) What is the Mfr & Model # of the Charge Controller ?
Q3) What are your expected Loads ?
You need to protect the raw cells from humidity and oxygen = severe corrosion
- 231 Forum & Website
