Partial off-grid system design questions....
I think I would pose the question this way. If there was a fire and it originated at the installation in question, would it be covered? If yes, I would get that in writing.
ASk the agent for it IN WRITING!
Easy enough.
House heating link:
Tom:
http://www.microcogen.info/index.php?topic=3537.msg38969#msg38969 uses engine block hot water into
hydronic loop in slab. charges batteries, heats house
Other heating ideas (mostly wood burners)
http://www.microcogen.info/index.php?topic=3502.0
Them's my toes!
Gotta love wood heat...mike95490 said:House heating link:
Tom:
Them's my toes!
And I built one of these over the summer... does pretty decent when the sun is out.
I just like tinkering... a lot. Lol... this is one of my other projects... all done by hand (shovel/pickaxe). Hoping to finish this spring. 14' round... 7' deep. Will make a nice storm shelter/root cellar when finished.
I'll do some more digging on the cogeneration system... Gotta keep busy when I'm off work or I go stir crazy... such as right now. I hate the winter months when I cant be working outside (or don't want to be I should say).
If I had a place to put it, I would love to build a rocket mass heater. Google it. Amazing how efficient they are and how well they heat living space.Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 8S (25.6V), 230Ah Eve LiFePO4 battery in a custom insulated and heated case.
As long as you have a way to swap out the oil drum they use at the radiant burn chamber, For long life, the masonry heater is the way to go.Horsefly said:If I had a place to put it, I would love to build a rocket mass heater. Google it. Amazing how efficient they are and how well they heat living space.
Another question...
At some point in the future, I'd like to upgrade to a nice MPPT controller... but for the time being, I plan to use my xantrex C35. It is rated for both 12 and 24v. It states in the manual that it's maximum charge rate is 35a listed under both 12v and 24v.
Does that mean it can handle double the amount of panels when wired at 24v compared to 12v?
Planning on going to 24v off the bat... but the inverter is gonna hurt. Don't want to buy a pricey charge controller right now if I dont need to.
Yep--You are correct. P=I*V ... You double V, you get 2x more power.
Note, some of the other controllers do have other limitations (working voltage input and output; and overall power)--So always refer to the manual for operational limitations.
