Partial off-grid system design questions....
2»
  • littleharbor2
    I think I would pose the question this way. If there was a fire and it originated at the installation in question, would it be covered? If yes, I would get that in writing.
    ASk the agent for it IN WRITING!
  • acidburn02zts
    acidburn02zts Registered Users Posts: 20 ✭✭
    Easy enough.
    House heating link:
    Tom:
    http://www.microcogen.info/index.php?topic=3537.msg38969#msg38969  uses engine block hot water into
    hydronic loop in slab. charges batteries, heats house
     Other heating ideas (mostly wood burners)
    http://www.microcogen.info/index.php?topic=3502.0
    Them's my toes!
  • acidburn02zts
    edited February 2017 #36
    mike95490 said:
    House heating link:
    Tom:
    Them's my toes!
    Gotta love wood heat...
    And I built one of these over the summer...    does pretty decent when the sun is out.
    I just like tinkering...    a lot.  Lol...    this is one of my other projects...    all done by hand (shovel/pickaxe).  Hoping to finish this spring.  14' round...   7' deep.  Will make a nice storm shelter/root cellar when finished.
    I'll do some more digging on the cogeneration system...    Gotta keep busy when I'm off work or I go stir crazy...  such as right now.  I hate the winter months when I cant be working outside (or don't want to be I should say).
  • Horsefly
    If I had a place to put it, I would love to build a rocket mass heater. Google it. Amazing how efficient they are and how well they heat living space.
    As long as you have a way to swap out the oil drum they use at the radiant burn chamber,   For long life, the masonry heater is the way to go.
  • acidburn02zts
    Another question...
    At some point in the future, I'd like to upgrade to a nice MPPT controller...  but for the time being, I plan to use my xantrex C35.  It is rated for both 12 and 24v.  It states in the manual that it's maximum charge rate is 35a listed under both 12v and 24v.
    Does that mean it can handle double the amount of panels when wired at 24v compared to 12v?
    Planning on going to 24v off the bat...   but the inverter is gonna hurt.  Don't want to buy a pricey charge controller right now if I dont need to.
    Yep--You are correct. P=I*V ... You double V, you get 2x more power.
    Note, some of the other controllers do have other limitations (working voltage input and output; and overall power)--So always refer to the manual for operational limitations.
