How do i effectively repair solar panels that have been surged
frenchheman
Registered Users Posts: 3 ✭
Hello. I have acquired several free solar panels. I mean alot!!! 400+
I would like to understand exactly how my solar panels work?
From cell to cell voltage, how to measure current and voltage.
If any ohms should go through a diode or not ( i know it should only go one direction, but is there minute ohms possibly in the other direction)?
And is there a way to measure voltage from diode to diode to see were the damage is in the cell loop?
And any relevant info that i could use.
I am prepared to measure and remove bad cells and replacewith new ones and reseal the entire panel
Thanks sincerely
Karl
Thanks sincerely
Karl
Here is a good (long) write up on how to assemble DIY panels.
http://www.fieldlines.com/index.php?PHPSESSID=2217ba36ada3e9efa590eb08bf4dac94&topic=145005.0
it may help you understand how to pull them apart for repair, and how to re-assemble.
Beware, the actual PV cells are thin, brittle wafers, and when they crack, become useless.
Sorry the link doesn't work!
How power should be per cell on a cs6x-305p 36volt 305watts Canadian solar 6x72 cell?
This is post from the link:
Oztules' series:
http://fieldlines.com/board/index.php/topic,144982.0.html
http://fieldlines.com/board/index.php/topic,144995.0.html
http://fieldlines.com/board/index.php/topic,145004.0.html
And this link may work better:
http://www.fieldlines.com/index.php/topic,145005.msg982721.html
- 621 Discussion Forums/Café
