Hair dryer
2»
    Dave Angelini Solar Expert Posts: 7,088 ✭✭✭✭✭✭
    Estragon said:
    Agreed. It's probably cheaper to move my carcass south for winter though, so that's my solution ;)
    Hard to beat Baja California in winter. I use to love Conception bay and the islands in the Sea.
     Arizona and New Mexico were favorites then but cold at night....
  • cupcake
    cupcake Solar Expert Posts: 254 ✭✭✭
    Estragon said:
    No way I could go without a generator in winter without massive battery and solar. Can go weeks with little sun from mid-Oct to mid- Dec and sun is too low from then to mid-Jan. Right now sun is around 17 degrees above the horizon, barely clearing a hill to the south. Even if I cleared acres of trees I might get an hour or so of weak sun.
    If you wanna do SOLAR off-grid, then go where the SUN is.  Otherwise just use a generator and call it a day... it's still off-grid and gets the job done... there's whole chucks of the USA and the rest of the world that get 90% sun year-round
    ~1.5Kw PV in parallel
    Morningstar MPPT-60 controllers (2) in parallel
    3 Trojan tr-1275's in parallel 450ah total
    Samlex 2,000 watt 12-volt inverter hardwired
