Hair dryer
Hard to beat Baja California in winter. I use to love Conception bay and the islands in the Sea.Estragon said:Agreed. It's probably cheaper to move my carcass south for winter though, so that's my solution
Arizona and New Mexico were favorites then but cold at night...."we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
Estragon said:No way I could go without a generator in winter without massive battery and solar. Can go weeks with little sun from mid-Oct to mid- Dec and sun is too low from then to mid-Jan. Right now sun is around 17 degrees above the horizon, barely clearing a hill to the south. Even if I cleared acres of trees I might get an hour or so of weak sun.
If you wanna do SOLAR off-grid, then go where the SUN is. Otherwise just use a generator and call it a day... it's still off-grid and gets the job done... there's whole chucks of the USA and the rest of the world that get 90% sun year-round
~1.5Kw PV in parallel
Morningstar MPPT-60 controllers (2) in parallel
3 Trojan tr-1275's in parallel 450ah total
Samlex 2,000 watt 12-volt inverter hardwired
