60 Cell panel VMP
Manufacturer Zhunyan
Polycrystalline
P max 250W
Voc 43.2V
Isc 7.72A
Vmp 36v
Imp 6.95A
Sys V 1000V
Power Tollerance +/- 3%
What stood out is the Vmp, from all the information I've researched, 60 cell panels are usually in the 30-30.4v range and are not recommended with PWM controllers, but with these? Could be those smaller Chinese volts, watts and amps like the legendary Powe Jack contraption uses, who knows . Google comes up with nothing for Zhunyan.
My first assumption would be that Zhunyan has no native English speakers who could draft a new label, so they copied it from someone else's 72 cell panel label.mcgivor said:Looking for panels I came across some 250W 60 cell with the following specs.
Polycrystalline
P max 250W
Voc 43.2V
Isc 7.72A
Vmp 36v
Imp 6.95A
Sys V 1000V
Hi mcgivor,
Agree that this is a bit suspect, especially for Poly PVs. There are some 60-cell PVs with Vmps in the 33-ish range, but believe that these tend to Monos.
Would bet that you would want to have the manufacturer confirm all of the spec values. If one divides the 250 W by the stated Imp, one does come up with 35.97 Vmp.
Also, the stated Power Tolerance if +/-- 3%. Most name-brand manufacturers have gone to, --0 - + 5W, or similar.
If you must buy these PVs I would, at the very least, write a Purchase Order, stating the conditions of acceptance by you ... although, perhaps where you are, such a document might have no standing, in reality. Also, using the Standard Flash Tube measurement, is very, very difficult for the average customer, in the field.
IMO, Vic
Don't think I would consider them when the manufacturer seems to not exist, there are better choices with names recognized by Morningstar's array caculator, all the panels I currently have are Schutten and so far so good so will stick with those.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
