Off-Grid Charger for Battery Bank?
timsim00
Registered Users Posts: 15 ✭✭
Hello.
Having moved into winter it is quite apparent that I do not have enough panels producing current for my batteries. Until I assess and make system modifications, I would like to purchase a batter charger to charge/top off my batteries after peak sun has diminished for the day. I have 3 questions pertaining to this and I hope someone can help me out.
My Battery Bank:
Four 6 volt Duracell FLA batteries, tied in series (12 volt) and parallel to give me 460AH, 50% @ 230AH.
Questions:
1. Are there any recommendations for a battery charger for my battery bank? I have a 3KW generator to power the charger.
2. Do I connect my battery charger across the parallel POS and NEG terminals and charge them as a bank of batteries?
3. Can I have the battery charger connected to the battery bank at the same time as my charge controller?
Thanks for any help on this! "Winter is coming!" Nope, already here! grrrrr
My Battery Bank:
Questions:
I have a Xantrex True-charge... Very good charger, you won't go wrong with one of them..
@westbranch Thank you for the suggestion.
I can charge my bank at one time as a whole?westbranch said:I have a Xantrex True-charge... Very good charger, you won't go wrong with one of them..
in the future try to size your system for winter-sun/winter daylight hours, and winter loads... this way you'll be golden year-round...
~1.5Kw PV in parallel
Morningstar MPPT-60 controllers (2) in parallel
3 Trojan tr-1275's in parallel 450ah total
Samlex 2,000 watt 12-volt inverter hardwired -
Ahhh...completely know that...um...now. ha. This is a 'this winter' solution. Thanks though!cupcake said:in the future try to size your system for winter-sun/winter daylight hours, and winter loads... this way you'll be golden year-round...
Yes - charge the battery bank as a single unit unless you are troubleshooting something.timsim00 said:@westbranch Thank you for the suggestion.
I also have a Truecharge 2 that I like very much, but they are expensive.
Marc's comment is correct, they can all be charged as one. But if you do not have them set up as a 'bank of batteries ' yet you can do them in pairs (in series so they are a 12 V battery) until you get the system set up for a winter workout... Check with your vendor and see if they recommend a 'commissioning charge'... This is a full charge followed by one or more EQ's...
have fun..
Question 3: In most cases yes but first chest with the manufacturer's recommendations.timsim00 said:Hello.
My Battery Bank:
Questions:
Thanks for any help on this! "Winter is coming!" Nope, already here! grrrrr1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I use a pair of Iota 12v 45amp (relatively) inexpensive chargers on my 12v bank from our hosts. I use the IQ controller, but I usually just bulk charge with the generator. Even in winter there is usually enough solar to finish absorb.Off-grid.
null
Sizing for winter would be pretty much impossible for me in Canada. I don't think I've seen more than an hour of bright sun for weeks.Off-grid.
I have 2 of the same battery's at 12 volt
I've just been running a 30 amp car charger for 11/2 hrs to bulk charge . When the sun comes out the solar panels and charger give me a full charge.
We went for 5 days of snow with no sun .
I use a 1400 watt champion Genarator and the charger draws 700 watts 10 hrs on a gallon of gasOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
- 234 Forum & Website
