Off-Grid Charger for Battery Bank?
timsim00
timsim00 Registered Users Posts: 15 ✭✭
Hello.
Having moved into winter it is quite apparent that I do not have enough panels producing current for my batteries.  Until I assess and make system modifications, I would like to purchase a batter charger to charge/top off my batteries after peak sun has diminished for the day.  I have 3 questions pertaining to this and I hope someone can help me out.
My Battery Bank:
Four 6 volt Duracell FLA batteries, tied in series (12 volt) and parallel to give me 460AH, 50% @ 230AH.
Questions:
1.  Are there any recommendations for a battery charger for my battery bank?  I have a 3KW generator to power the charger.
2. Do I connect my battery charger across the parallel POS and NEG terminals and charge them as a bank of batteries?
3.  Can I have the battery charger connected to the battery bank at the same time as my charge controller?
Thanks for any help on this!  "Winter is coming!"  Nope, already here! grrrrr
    I have a Xantrex True-charge... Very good charger, you won't go wrong with one of them..
  • timsim00
    @westbranch  Thank you for the suggestion.
    I can charge my bank at one time as a whole?
  • cupcake
    cupcake Solar Expert Posts: 254 ✭✭✭
    in the future try to size your system for winter-sun/winter daylight hours, and winter loads... this way you'll be golden year-round...
    ~1.5Kw PV in parallel
    Morningstar MPPT-60 controllers (2) in parallel
    3 Trojan tr-1275's in parallel 450ah total
    Samlex 2,000 watt 12-volt inverter hardwired
  • timsim00
    Ahhh...completely know that...um...now. ha.  This is a 'this winter' solution.  Thanks though!
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,175 ✭✭✭✭
    edited December 2016 #6
    Yes - charge the battery bank as a single unit unless you are troubleshooting something.
    I also have a Truecharge 2 that I like very much, but they are expensive.
    Marc's comment is correct, they can all be charged as one.  But if you do not have them set up as a 'bank of batteries ' yet you can do them in pairs (in series so they are a 12 V battery) until you get the system set up for a winter workout... Check with your vendor and see if they recommend a 'commissioning charge'...  This is a full charge followed by one or more EQ's...
    have fun..
  • mcgivor
    timsim00 said:
    Hello.
    My Battery Bank:
    Questions:
    Question 3: In most cases yes but first chest with the manufacturer's recommendations.
  • Estragon
    I use a pair of Iota 12v 45amp (relatively) inexpensive chargers on my 12v bank from our hosts. I use the IQ controller, but I usually just bulk charge with the generator. Even in winter there is usually enough solar to finish absorb.
  • Estragon
    null
    Sizing for winter would be pretty much impossible for me in Canada. I don't think I've seen more than an hour of bright sun for weeks.
  • wellbuilt
    wellbuilt Solar Expert Posts: 763 ✭✭✭✭
    I have 2 of the same battery's at 12 volt
     I've just been running a 30 amp car charger for 11/2 hrs to bulk charge . When the sun comes out the solar panels and charger give me a full charge.
     We went for 5 days of snow with no sun .
     I use a 1400 watt champion Genarator and the charger draws 700 watts 10 hrs on a gallon of gas
