Why the rubber tips on MC3 connectors?
softdown
Solar Expert Posts: 4,081 ✭✭✭✭
Is this for weatherproofing? Fighting corrosion?
For example: http://www.ebay.com/itm/MC3-connector-pair-female-male-solar-cells-panels-4mm-/220952870533?hash=item3371d13e85:g:liYAAOxyY3ZRsLfN
softdown said:Is this for weatherproofing? Fighting corrosion?
Yes, basically to prevent water intrusion. MC4 use an 'O' ring.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Thanks...and thanks for the MC3 clam shells. Found some more cheap enough....shipping was $17 for 50 pairs. 50 pairs may weigh about 1/2 pound...or so. People wonder why so many just jump to Amazon or Ebay? Canadian stores wanted $75 to ship FedEx. Said that Canada Post would not work....which is BS. Our host doesn't carry them.Photowhit said:softdown said:Is this for weatherproofing? Fighting corrosion?
MC3 connections are fine when the clam shell is used. Though I do have to augment with tape on 1/2 the connections. That is due to slightly different specs between the MC3 connectors and the clam shells.
