12v System Connection configuration Questions
Ungridded
Ungridded Registered Users Posts: 4
Hello, My system contains the following...
6 - Kyocera KC130TM solar panels. (21.9Voc 8Amps)/(17.6Vpm 7.39Ipm)
1- Outback Flexmax 80 controller
1 - Xantrex SW2512 Inverter
4 - Trojan L16E-AC 370 AH @ 20hr
The system is going to be set up as 12v DC and my question is this... Can I connect my panels in series-parallel in two strings to roughly get 35v @ 16 Amps. so as to charge the batteries more effectively?
Thanks in advance.
    Pretty much have to run them 2 in series! 17.6 volts is not enough room above the charging voltage for the mttp type charge controller to work properly. I think you will be charging at about 5% during sunny days might want to add some panels if you will be using this daily. Fine for a weekend cabin...
  • Ungridded
    Thanks Photowhit, Yes this is an off-grid weekend cabin. We only use it once or twice a month for a few days at a time. So, would it be better to connect all of the panels in series for ~105v @ 8Amps? or Series-parallel should double the voltage AND current no? or Should I not worry about the current for charging the batteries?
    No more than 3 panels in series, otherwise you will start loosing power in the controller.   3 in series may give you enough headroom to move to a 24V battery bank, but you have few options with 6  panels and 12V
    Like Mike said.
    3 in series also has the advantage of not requiring a combiner box!
  • Ungridded
    So, if these are my panels, would this connection be correct? Sorry, This is a first for me.
    Yep! In general, your charge controller would run cooler with 2 in series and 3 parallel strings but you would want a combiner box (fuses or breakers) for each string. Heat and electronics don't mix well. I like that you could move to a 24 volt system without changing the configuration. Many find that loads grow and would want to move to a higher voltage system in time.
  • Ungridded
     Photowhit, Thank you for your opinion and guidance. I very much appreciate it.
    I just got there first, lots of sharp people here!
