Where does the temp sensor go?
Old Guy
Registered Users Posts: 51 ✭✭
I purchased a remote temp sensor for my Morningstar TS60 and the manual really does not say WHERE it goes or I missed it three times.
It has a battery lug type connector on the end. Does that actually attach to the battery or is this just for mounting it inside the battery box?
If it goes on the battery, does it go on the pos or neg terminal?
Put the sensor on a positive terminal. That will best reflect the true battery temperature as it heats up while charging.
So its actually just a heat sensor and not a electrical connection?
"So its actually just a heat sensor and not a electrical connection? " Yep..some prefer to tape it on the side of the battery about half way down
Thank you guys again... The lug terminal threw me off.
Old Guy said:Thank you guys again... The lug terminal threw me off.
Two schools of thought from lead acid battery design engineers whom I have spoken with:
- "Connecting to the terminal gives the sensor a thermal pipeline into the battery interior"
- "Sandwiched between batteries insulates the sensor from the ambient and sees the lag from all of that mass"
Rolls Batteries manual say NOT to attach it to any terminal but to tape it half way down a battery in the centre of the bank which is what i did and i have found the reading on the ts-60 to matched the reading of the fluid with a thermometer precisely . The RTS having a terminal connector looks to indicate it should be attached to a terminal however there might be other reasons for that , dont think its conclusive .2240 Watt Array 4 x 460 Watt Mono Panels + 2 x 200 Watt Panels
Victron Smart 150-70 MPPT Charge Controller
24 volt Battery Bank 4 x 6v 400 Amp/Hr Trojan L16 AGM
LiFePO4 Lithium 100 Amp/Hr Battery for Backup
Victron 1600w Multiplus Compact Inverter/Charger
DC to DC Charger ( Non Isolated ) -
Some folks will take a block of Styrofoam, make a hollow spot for the sensor, and tape/glue/jam between batteries/battery box to side of battery. The Styrofoam will ensure that the sensor is measuring battery temperature and not ambient air temperature.
Great idea , will do that tomorrow , might not make much difference on my system now but its sure to in the winter .2240 Watt Array 4 x 460 Watt Mono Panels + 2 x 200 Watt Panels
- 227 Forum & Website
- 618 Discussion Forums/Café
