Delete
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
Delete
I'm wondering if 10 ton is enough for 4/O wire, maybe just marginal. Some good tables and crimp pics here
https://www.temcoindustrial.com/product-guides/tools/crimping-tool-selection-guide.html
Battery interconnects are not a UL listed usage of welding cable (which needs special lugs). MTW cable is listed, but sill needs special lugs.
