Disconnect order
Chris11
Registered Users Posts: 130 ✭✭
I just finished making my bat box with ventilation....so had to change the wiring somewhat. A new item I put in was a disconnect switch that can simultaneously disconnect both feed from the panel to the CC, and feed from the CC to the batteries. I didn't "throw the switch" yet as I started to wonder if that can do damage to the CC somehow.
Thanks, Chris
Thanks, Chris
as a habit I like to shut off the PV input to the CC first, then the CB to the battery. , Reason is most CC's like to be powered up before the PV is connected as they will not run on panel output, just the battery output.
Agreed, always battery first, wait for startup sequence, then solar. Disconnect in reverse order.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Thanks for your replies.
Yep....I understand that. But will simultaneously disconnecting/reconnecting both hurt anything, I'm chomping at the bit to turn it on....although here in Eastern WA we haven't seen the sun for a month. Feels like Seattle which likes to pretend it's on the coast when in reality it ain't....it just rains so much there that water is everywhere.
Personally I would not recommend both simultaneously as the solar open circuit voltage could be much higher than the battery voltage and could potentially damage your controller.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Breakers are cheap. Charge controllers aren't. Strongly recommend you nix the 2 pole and just buy 2 single pole.
If that is a double pole breaker and not a switch as you stated, you can simply drill out the pin bonding the 2 breakers and have 2 single pole breakers. Hope you do have breakers or fuses in your system though.
Thanks all. Last night I emailed Morningstar for the their answer. Just as you all suggested...they also suggested NOT to simultaneously disconnect both sides of the CC.
It is a double pole double throw switch, not a breaker. I was just using one throw but both poles. I'll now put another switch into the CC to bat. line. And yes I have a fuse in each segment of wire.
Again, thanks to you all for taking the time to reply.
Chris
- 621 Discussion Forums/Café
