outback fan
petertearai
petertearai Solar Expert Posts: 471 ✭✭✭✭
.hi . it would seem that the internal fan on my fxr24 inveter is on continually . I have about 100 watts load on it .internal temps are tx = 40 deg c
fet = 37 deg
caps = 54 deg
has been like this fir days . .environment temps about 18 deg day and 12 night . maybe the cap temps . is thus normal??
    Is this a new? I know my Prosine will run the fan with a load of about 300 watts, pretty much continuously unless the ambient temps are below about 50 degrees (10 degrees C) I also know it will over heat with a load around this high without the fan. I had the fan go out a couple years ago.
    Dave Angelini Solar Expert Posts: 7,095 ✭✭✭✭✭✭
    edited October 2016 #3
    Definately not normal for a 24V FX. Call Outback for a kit or RMA.
    Oh yea,  does it start a large load like a 1500 watt heater?
  • petertearai
    Thanks for replys . it is about a year old .will try the heat gun as a load on it . yesterday I ran the washing machine ( around 300 watts).. fridge also running fine (inveter fridge) so soft easy starting .. will phone the supplyer today .
  • petertearai
    spoke to dealer . they say it needs a look at . so will disconnect after weekend and they say it should be a same day turnsround. .. so looking like my first power cut in over 10 years .. my neighbors on the grid however have many power cuts per year , as we are at the end of a spur line..
  • softdown
    softdown Solar Expert Posts: 4,062 ✭✭✭✭
    Seems like I have read that low batteries may contribute to the inverter fan turning on? I'm not sure though.
  • petertearai
    took inveter back to dealer . fet pwb replaced . now fets and capacitors report the same temp .  36 deg and 37 deg . tx reports 38 deg . .all good now . and all done quickly under warranty .
