Anybody ever replaced the valves on a 500 gallon propane tank?
softdown
softdown Solar Expert Posts: 4,054 ✭✭✭✭
A lot of us off gridders use propane. Now that we may get it for $1/gallon during the slow summer months, we may wish to "stock up".
A friend of a friend is a scrapper. He sometimes cuts up old propane tanks and uses them on trailers. So I might get a cheap price.
I figure an empty tank is probably a leaker. Who runs all of the propane out of a tank then lets it sit and turn to scrap?
Is it feasible to buy and replace the valves? I have heavy duty tools that allow for significant torque to be applied. I have also done significant plumbing (mostly on reef tanks).
  • solar_dave
    Should be pretty easy to test with compressed air and some soapy water.  I think that you will find that the propane fillers will have a problem with filling a non-certified tank, better ask your dealer.
    Just remember that you do not "static test" pressure tanks with compressed air--They use water (or other incompressible fluid) to test tanks. If the tank "lets loose" -- Much less dangerous vs a tank filled with air.
  • Johann
    Johann Solar Expert Posts: 245 ✭✭✭
    We actually done the thing you mentioned. We ran it empty and let it sit for many many many years and the tank did not have a leak.
    We started to heat our home with wood and while we did not use the propane tank the propane gas company charged us a leasing fee in the meantime since we did not purchase the gas with them anymore.
    The only problem was that the gas tank was not their property at all and I had to threaten them with a lawsuit and they dropped the leasing bill.
  • softdown
    They are both very careful and wanting to sell some propane and earn a living. A mechanically sound tank with new valves is about as safe as one can be. The tanks can probably handle ten times the pressure they have, the valves are the trouble spot when there is one. Assuming, of course, that the owner kept the tank generally free of rust. Having troubles posting. Board trying to tell me something?
  • 706jim
    706jim Solar Expert Posts: 527 ✭✭✭✭
    One comment I will make about propane tanks is that they CAN be positioned a considerable distance from your home. Just in case it ever caught fire or blew up at least there would be some buffer distance between it and you.
    Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
  • mcgivor
    edited December 2016 #7
    Most pressure vessels will have a test date stamped on them somewhere, when expired, 10 years generally, recertification using a hydrostatic test is required to extend the use of the tank. Smaller propane tanks are generally worth less than the cost of the test and therefore essentially disposable. Most, if not all, companies who sell/refill propane tanks will refuse to fill an expired tank, as it would make them liable should anything go wrong. So unless there are no regulations in your country or state, liability laws don't exist and life is generally cheap, testing with compressed air and soapy water will be of little use.
