PV Array Sellection
asadiftikhar
Registered Users Posts: 1 ✭
I have a Hybrid Inverter
1 KVA/600W/24VDC
Max PV input VOC = 75VDC
Max PV input power = 600Watt
PV array MPPT voltage range = 30~66VDC
MPPT charge Controller = 20Amps
Can I connect the pv panels in,
3x Panels of 100W/8.11A (18.5VMP/22.2VOC) in series = 300W/8.11A (55.5VMP/66.6VOC) = Bank1
Then connection of 2 Banks in Parallel = 600W/16.22A (55.5VMP/66.6VOC)
Is it possible?
1 KVA/600W/24VDC
Is it possible?
Your math is incorrect as you have 1800 watts of panels here. The inverter you describe sounds like one of those cheap NON UL APPROVED Chinese imports. Not legal for grid tie.
I don't see 1800 watts of panels.littleharbor2 said:Your math is incorrect as you have 1800 watts of panels here. The inverter you describe sounds like one of those cheap NON UL APPROVED Chinese imports. Not legal for grid tie.
One string = 300 watts of panels
And the other string = 300 watts of panels.
Total = 600 watts of panels.
Am I missing something?
My bad here, Don't know what I was thinking. Please disregard my entire comment. In my defense it was early and the coffee probably hadn't kicked in .
