PV Array Sellection
asadiftikhar
asadiftikhar Registered Users Posts: 1
edited July 2016 in Solar Beginners Corner #1
I have a Hybrid Inverter
1 KVA/600W/24VDC
Max PV input VOC = 75VDC
Max PV input power = 600Watt
PV array MPPT voltage range = 30~66VDC
MPPT charge Controller = 20Amps
Can I connect the pv panels in,
3x Panels of 100W/8.11A (18.5VMP/22.2VOC) in series = 300W/8.11A (55.5VMP/66.6VOC) = Bank1
Then connection of 2 Banks in Parallel = 600W/16.22A (55.5VMP/66.6VOC)
Is it possible?
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,189 ✭✭✭✭✭
    edited July 2016 #2
    Your math is incorrect as you have 1800 watts of panels here. The inverter you describe sounds like one of those cheap NON UL APPROVED Chinese imports.  Not legal for grid tie.
  • Johann
    Johann Solar Expert Posts: 245 ✭✭✭
    I don't see 1800 watts of panels.
    One string = 300 watts of panels
    And the other string = 300 watts of panels.
    Total = 600 watts of panels.
    Am I missing something?
  • littleharbor2
    edited July 2016 #4
    My bad here, Don't know what I was thinking. Please disregard my entire comment.  In my defense it was early and the coffee probably hadn't kicked in .
