Greetings from new user (pics inside)
13»
  • icarus
    Re: Greetings from new user (pics inside)
    Ole,
    600 ah battery with only 11 amps of charge capacity is a bit light. I understand you only draw on the weekends,,, and have the week to recharge,, but going forward,, more panels might be welcome.
    He's just doubled the array size, but sure, more power is always nice to have.
  • icarus
    I realize that he has doubled his PV,,, but even with the doubling he is still at the very low end of the range.
  • _OS_
    _OS_ Solar Expert Posts: 207 ✭✭✭
    Hi Tony,
    Yes I know I am on the low end of the range but I also have a generator that I can connect to the Victron inverter. The Victron inverter has a built in 50A charger.
    I have only charged the batteries twice so far using the generator (last fall and a right after I bought the system in 2007). I guess this will change soon because I am installing a water system (a water tank that I fill up manually, with a pressure triggered, 130W pump and propane water heater). I will also install a digital TV decoder so my kids can watch TV.
    Ole
  • icarus
    Ole,
    Youare discovering the slippery slope of loads! Water pump,, TV, satellite dish,,Internet dish/modem. You are where I was 10 years ago. Keep resisting the urge for more loads,,,,, betcha can't!
    Good luck,, sounds like you have a nice spot. Are you just about through your ice season? We have had warm days,,, +15c with overnight lows ~-5. All the snow is off the ice,,, and the bush is getting bare here and there. I suspect our ice will be out in about another 3 weeks or so.
  • dagr51
    dagr51 Solar Expert Posts: 72 ✭✭✭✭
    Is your water tank underground? Mounted on a platform or some other way to take advantage of gravity? How large? How do you hump water in to your cabin? Lots of questions, but you have gotten my attention!
  • _OS_
    dagr51 wrote: »
    Hi,
    Please remember that my cabin is in Norway not far from the Arctic Circle.
    My water tank is 80 liters and sits on the floor inside the cabin and I have to carry the water in buckets from a near by river and poor into the tank. The law in my country allow me to do this without any wastewater treatment. If I run the water through a pipe from outside the cabin to the inside I have to install a large and expensive wastewater treatment system.
    Ole
  • dagr51
    Got it. Thanks for the update!
  • _OS_
    icarus wrote: »
    Ole,
    Yes I am discovering the slippery slope of loads. At the same time I have also made up my mind to run a 12V cable from the tool shed to the cabin for lighting during night time. This way I can turn off the inverter and save a few Ah. I have also, as I wrote in another thread, ordered a SureSine inverter that has much lower no-load self consumption. I will use relays in the tool shed and a switch in my cabin to switch between the two (during my search for relays to use I discovered that this was not as easy as I thought. More on that later).
    The temperatures you have are almost identical to the temperatures over here now. In the city, where we live the snow is almost gone.
    Ole
  • solarnewbie
    solarnewbie Registered Users Posts: 11
    Hi OS,
    I'm curious about your earlier specs ( 1 80w bp panel and two 350A batteries)
    What did you use on those in terms of TV and Lights and for how long?
    BB. Super Moderators, Administrators Posts: 33,726 admin
    SolarNewbie,
    You can very roughly size an Off-Grid solar systems AC (120/230 VAC) output by:
    • Number of "Full Sun" hours per day... 5-6+ hours per day in summer (equivalent to "noontime sun").
    • Size of Panel in Watts (assume ~82% of factory rating)
    • Assume flooded cell storage battery (80% efficient) and reasonably efficient AC inverter (85% efficient)
    • Derating factor of 52% (or 0.52) from above
    • Assume fixed mounted (not tracking array) tilted at the angle of your latitude.
    Assuming you are in a very sunny area and get 6 hours of sun per day (UAE?)
    80 watt panels * 6 hours sun per day * 52% = 240 Watt*Hours per day
    If you have a 50 watt TV running 2 hours and a 13 watt CFL lamp for 4 hours:
    100 Watt*Hours = 50 watts * 2 hours (TV)
    52 Watt*Hours = 13 watts * 4 hours (CFL Lamp)
    152 Watt*Hours of daily load
    So, an 80 watt panel could easily supply the above load (240WH of energy vs 152 WH of load)...
    If you are making an off-grid system for daily use (vs an emergency backup power which may have fewer batteries)--we usually use the rule of thumb for 3 days of no sun plus a maximum of 50% discharge... Or the battery would be sized:
    3 days of no load * 1/50% = 6x your daily operating load.
    To figure out 350AH x 2 of 12 volt batteries and how much recommended load:
    350 AH * 2 batteries in parallel * 12 volts / 6 battery sizing factor = 1,500 Watt*Hours of useful storage...
    In this example, with my above example load of ~152 Watt*Hours per day, such a battery bank would supply:
    1,500 Watt*Hours / 152 Watt*Hours per day = 9.9 days of "no sun" storage...
    Now, we would recommend that your batteries be charged at 5%-13% of the batteries 20 Hour AH rating...
    350 AH * 2 * 12 volts * 5% = 420 watts of solar panels
    350 AH * 2 * 12 volts * 13% = 1,092 watts of solar panels
    If you don't have enough solar panels, then normally we would expect that a generator would need to be used once in a while to recharge your battery bank (typically, run the genset when the batteries fall below 75% state of charge).
    Anyway--you really need to understand your loads/needs and how much sun you have available in your area (by season, if it matters). Then we can help size your system to your needs.
  • _OS_
    Hi OS,
    We are usually not using the system for more than three days at a time with an average draw of around 50Ah per day.
    OS
  • _OS_
    edited June 2016 #74
    Hi!
    It has been a while since I posted my first message here in 2008. In the years after that I have slowly upgraded my system. First from Morningstar Sunsaver MPPT to Rogue MPPT and now Morningstar Tristar MPPT 60 charge controller. My battery bank have stayed the same until last fall, two Concorde 12V 305Ah batteries. Three years ago I upgraded my system to 24V and rewired my old Concorde batteries from parallel to series. I also upgraded my solar panels to two 200W panels. Finally last fall I replaced the Concorde with 12 Fuli 200Ah/6V batteries for a total of 600Ah/24V.
    My cabin is in the Norwegian mountains and it can be very cold during the winter and two times I have experienced that my batteries have frozen while deeply discharged. So now I finally have decided to build a new "tool shed" with a cellar underground where I can store the batteries. Hopefully the temp will be above freezing in the cellar.
    I had a company dig the hole and make the concrete walls but the woodwork I will do myself. Below are a couple of pictures. I will post more pictures later. And yes, the distance from the ground to the top of the concrete is too small. It should have been at least 20cm (8 inches). I need to fix that.
    Ole
    Hi Ole,
    Nice to hear from you again--I missed you.
    You were working on your own battery monitor design (as I recall)--Did you ever get a chance to finish it?
  • vtmaps
    I hope you have designed a clever, near effortless system to get batteries in and out of the cellar.
    edited June 2016 #77
    A "floor hatch" with overhead block and tackle?
  • _OS_
    BB. said:
    Hi Ole,
    Hi Bill,
    Yes I made a remote display for my battery monitor that I used for a couple of years. I have since upgraded my system and now I have an Android app (mentioned in another thread on this forum) that reads the essential data from my Tristar MPPT 60.
    Yes I plan to have a floor hatch (the "cut out" can be seen in the picture above) and a tackle.
  • _OS_
    Hi everyone!
    My project is coming along very well. Below are a couple of pictures.
  • Estragon
    Looking good!
    As well as helping keep the batteries warmer in winter, having them underground will keep them cooler in summer. Mine are in an enclosed and mostly insulated crawlspace, which really moderates temperature in a climate likely similar to yours. Keeping them cooler should help them last longer, but they do lose some apparent capacity.
  • _OS_
    A lot of snow this winter! This was taken a couple of weeks ago:
  • _OS_
    edited September 2018 #82
    Hi again!
    Have moved my batteries to the cellar this summer. In the picture below the battery bank to the right is my main bank. The four Concorde to the left are for "emergency" and can charge the main bank via a DC/DC converter. I control this remotely via an app on my mobile. Also I doubled my PVs (to 800W) and made a mount for them.
    PS: Should I move this to another thread since I am not a new user anymore?
    Hi Ole,
    I would suggest you keep adding to this thread... It is fun to watch as your system evolves over time.
    I cannot tell for sure--But the solar array mounting looks like it may need more "fore/aft" bracing???? I am worried that a wind gust could fold the mount "flat" to the ground (I see some wire bracing, but I don't think it is enough).
    Also, you have a small diameter (gauge) red wire from the battery + bus back up to the main panel (power for a battery monitor or something?).
    It may be the photo, but the wire looks to be in very poor shape (burned/failing insulation?). Ideally, the wire should be checked and possibly placed in a secondary tube of some sort to reduce the chances of a short circuit/damage. Nominally, a fuse should be placed between the battery + bus and the wire (near + bus) to protect against downstream shorts.
    Another option would be to move the battery + (and -) connections into your DC wiring box (connect via fuse to the + bus in the DC panel). That would help protect your small diameter wiring from damage/issues with the battery bank exposure.
    Take care,
    Bill
  • _OS_
    edited April 2019 #84
    Hi again!
    Sorry for my late reply! Everything is going well here. We have had two storms this winter and my solar panel mount is still standing :-)
    I will spend a week in stretch at my cabin for the first time now. I am at day four now and each day my batteries goes to absorption.
    Also we have much more snow now than usual. The picture below was taken today (my new shed in the background).
    I have also finished the internals of the shed. I have used pine everywhere since that is cheap and available here. I made the workbench myself by gluing together 2x4"s. Also you can see the hook I use for lowering the batteries into the cellar.
  • _OS_
    Below is a better view of my batteries in the cellar. The batteries to the left are my old + my brothers old (four SunXtender 300Ah in 2s2p configuration). I use them to charge my main batteries in the darkest months. I use the blue box in the lower right to charge them. It is a Victron DC/DC converter that can bulk charge. The relays to the right of it is to reverse the direction of the charging, so I can charge the spare batteries from the main bank when the main bank is fully charged.
    The white cabinet is a Midnite Solar Mini-DC. The gray one to the right of it a 12V DC/DC that I use for a Control By Web relay as well as my mobile broadband router seen in the other picture. Finally, the blue box to the left is another 12V variable out DC/DC that powers a kerosene/diesel heather (pictured) in the main cabin. The kerosene heather can be started remotely with a text message from my phone.
