12v solar getting no current
Menace_87
Registered Users Posts: 3 ✭
hey i have 12v solar i accidently shorted the solar controller. i brought a new one connected it but solar panel is giving me no current.
what damage could i have done to the solar panel without removing it from the roof to look.
Welcome to the forum,
Do you have a DVM (digital volt meter)? We can use that to do some troubleshooting.
Also, please tell us about the whole system... battery, controller, inverter, solar panel, etc.
What exactly do you mean by "shorted the solar controller"?
the inverter is 30amp projecta solar panel is 200w 110ah battery. Apart from that im not sure i didn't buy it i have just connected it i have a DVM. i connected the last solar controller but the positive terminal come off the battery and without thinking i quickly put it back on which caused the controller to smoke. so i replaced it and now im not getting any amps from the solar.
Many Charge controllers MUST be connected to the battery first. The controller you refer to is a 12/24 volt type. The controller sees the voltage of the battery and decides which nominal voltage the system is. While you are still being vague as to what exactly your equipment is it's my guess that your 200 watt panel is a 60 cell grid tie version which is not suited to battery charging without a true MPPT charge controller. The charge controller you are using isn't a MPPT controller. While it will work (sort of) you will only be getting approx 1/3 of the charging potential of your panel.
Littleharbor2 may well be correct!
- "While it will work (sort of)"
Pulled it all apart now. 200w mono is putting out power and projecta sc030 controller isn't picking it up so will check my mc4 extension leads tomorrow.
If they are fine could there be a reason why the controller is not receiving the power from the solar?
the solar panel come with a pwm controller i have no idea what the projecta sc030 is.
sorry for not knowing much about this.
