Chinese solar AGM batteries
junglejoe39
Registered Users Posts: 34 ✭
I purchased 6 Fullriver DC1150-2 2volt cells for my modest 12 volt rv battery bank. I absolutely love them. They are made in china but I understand them to beone of the best AGM's on the planet. I am absolutely happy with them.1987 Avion 9.1 Metre with 5 Kyocera 270 watt panels, Midnite Classic 150 mppt controller, Approx 14.4 KW provided by 6 in series Fullriver dc1150-2 2 volt agm cells, Exeltech 2Kw pure sine inverter, Battery transfer switch to isolate pesky converter from solar components, 120 amp battery to battery charger to allow dc back up from tow vehicle and 2 Honda 2000 generators for the very rare need to back up. Networked with Cradle point AER2100 router ATT/ Verizon, WiFi as WAN on Exeltech 125 watt inverter. Microwave, 2 induction cook tops, Mr. Coffee and a pretty nice toaster.
Ditto, My DC 250-6's are rock solid. They sat unattended for over a year and show no ill effects as well.
How many years? I have never heard of an AGM that was cycling offgrid lasting more than 6 years.
The Baja must be heating up nicely! Fish time! Where are you please and was your boat a Little harbor?"we go where power lines don't" Sierra Nevada mountain area
Just for what it's worth: I know of several off grid AGM battery banks running 7-10 years in cooler climates.
Here in South Central Texas on 100% off grid systems, good AGM's tend to run 5-7+ years with properly designed systems.
Like FLA's, not all AGM's are the same.
The oldest Fullriver AGM off grid bank that I have personally seen is currently 4 years old and running strong. I have personally capacity tested Fullriver L16 6v and 2v batteries and the ratings were accurate. How long will they ultimately last? Who knows.......
Fullriver now offers a 7 year warranty on renewable energy applications.
Does it ever make sense to provide active refrigeration to RE batteries?
Yes, if you do it as an opportunity load. Somebody else on this forum is using an old fridge as a battery box and runs the fridge during absorb and float.jonr said:Does it ever make sense to provide active refrigeration to RE batteries?
Yes indeed.
I have a customer in Louisiana who ran the numbers based on a 50% reduction in life for each 10 deg C rise in battery temperature for his AGM's. With his huge investment in batteries, and the relative low cost of PV, he opted to maintain the battery vault at 85 F maximum using a combination of refrigeration and passive cooling methods.
Several people have built systems that "steal" a small amount of cool air from inside their homes to help temper the battery room/box/vault.
With AGM batteries, I would have guessed that he would just put them in air conditioned living space. Hmm, looking at the prices of these batteries ($1000/year?), I'd go buy a new freezer to put them in.
Compared to our $0.10/KWH power cost (no tiers, no demand charges) no RE or battery systems make sense from a straight economic point of view when power is readily available. Around here, PV/wind/micro-hydro with battery bank system installation is driven by the extreme cost of pulling utility power to remote properties. Numbers like $30K and $45 make alternative energy very attractive.
But many systems are being built by people who want to prepare for a "grid down" scenario. These systems sit on float waiting for the big event.
I would love to hear where you came up with $1,000 per year, and how does that compare to other batteries that you have analyzed?
Being far from an expert, I am always willing to listen and learn.
Not at all accurate, I just used $500 per battery and 12 of them to get 24V. So $6000 and perhaps they last 6 years (hot climate without refrigeration). Very rough guesses say that the Tesla Powerwall might be similar. I agree that $20K upfront (more made up numbers) plus $1K/year in batteries sounds better than $40K up front plus $500/year utility bills.
Batteries are the weakest link for sure. With a great design and really good care, Remembering that all batteries are not created equal, a 7-10 year battery life is doable.
Friday, I got an order for (24) small 2v AGM batteries to replace a bank installed in February 2006 in North Texas. It is a 31 KWH battery bank. Two of the batteries are starting to show a lower voltage that the others, so the owner wants to replace the bank. It's off grid so he needs reliability.
He paid $223. each for these American made batteries back in 2006, so a $ 5400. investment not including labor.
The scrap lead value for his batteries today is about $500., so about $4,900. spent on batteries.
So, this one is right at $500./year. The new batch will cost more of course....
maybe off topic . but . has anyone got any experience with flooded carbon batteries?
http://www.solarchoice.net.au/blog/giant-power-lead-carbon-batteries-home-energy-storage
2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
- 234 Forum & Website
