The cost of Solar Power System
Panels: SILLIA 320 W. POLY ?
Battery: GNB opzV,1957 Ah ?
String Box: PN-GCBB- 8 Strings, 80A, 275 VDC, IP66 ?
Charge Controller: STUDER charge controller VT-80 ?
Inverter: Studer XTH 6000-48-6Kw?
Monitoring System: Remote controller Studer RCC-02, Communication Set Studer Xcom-LAN, Temperature Sensor Studer BTS-01?
Main Battery Switch: With Circuit Breaker ?
Other Electronic Components: MC4 Connector for Panels male and female?
Earthing complete Kit 25m?
Individually Designed System installation Kit?
Control Cabinet Studer X-connect?
Earthing Cable Kit with Ring Terminals?
PVC Cable Conduit ?
Aluminum Profile Bar Kit for Inverter Mounting?
Changeover Switch Moeller 63A?
Battery Rack Kunstmann?
AC Circuit Breaker?
Pease if someone what are the prices of these equipment ?
The sponsor site for this discussion board sells some pretty good equipment at fair prices. Personally I don't recognize most of the brands such as Sillia and Studer you mentioned. Are you located in N. America?
48v Rolls 6CS 27P
Hello yes man i am in North America?
but please can you price them please for approximate prices ?
because i want to buy it from someone and i do not know if it is in good price?
Andrew, Just use Google and compare pricing and customer reviews. I'd suggest looking a products more available in the US. Your stuff all looks to be from Europe.
48v Rolls 6CS 27P
I believe you are currently in Saudi Arabia (possibly elsewhere in Italy/Europe).
We are all volunteers here, and do not really do quoting of prices.
Our host (who pays the bills for the forum and lets us post here for "free")--Is Northern Arizona Wind and Sun:
http://solar-electric.com/
They have vary reasonable prices and good service/support. However, in Europe, prices (and import/customs duties) can have quite a bit higher pricing.
The product names you mention (and I recognize) are all good quality European equipment manufacturers. But, in the US, much of this equipment is probably "too expensive" for most of us in the US (there are some European products here that have relatively good pricing too--Have to hunt around for the suppliers--NAWS does sell some Euro product--But then we get into the 120/240 vac 60 Hz vs 230 vac 50 Hz issue--So still may be difficult to compare exactly).
For example, a quick search for one of your products returns:Control Cabinet Studer X-Connect System - Stafco Webshop
That is ~€2,140 Euro--and possibly out of Belgium(?). Is that a good price or not? I Do not know. How much would it cost to ship/insure/bring through customs--Don't know that either.
What we try to do here is help people understand their loads, do a paper design of the "generic system", then recommend "classes" of hardware that could work for you (i.e., small system vs large system components are "different").
hi everyone they told me all of these will cost me 50000 Euro? is this good deal? please
You have not told us how many solar panels.... Or if you are looking just hardware or including labor.
Assuming about 12,000 watts of solar panels, €50,000 is certainly possible for just the off grid solar hardware and battery bank.
$12,000 for solar panels and $20,000 USD for 2,000 AH @ 48 volt lead acid forklift battery bank... Without shipping+taxes included.
$2,000 for solar charge controllers and $4,000 for an 8,000 watt a.c. Inverter.
Close to $38,000 for basic hardware (no wiring, no panel racks, no taxes/shipping, no labor). In Europe with higher costs and taxes, €50,000 for a complete system hardware package does sound plausible.
hello MR Bill I am sorry for later I was traveling to different country.
I would like to ask you please for clarification please.
your comment is not clear for me do you mean is it good price or not? however for clarification i will specify the offer
24 Panels: SILLIA 320 W. POLY
24 Battery: GNB opzV,2V,1957 Ah
2 String Box: PN-GCBB- 8 Strings, 80A, 275 VDC, IP66
2 Charge Controller: STUDER charge controller VT-80
1 Inverter: Studer XTH 6000-48-6Kw
Monitoring System: 1 Remote controller Studer RCC-02,1 Communication Set Studer Xcom-LAN, 1 Temperature Sensor Studer BTS-01?
Main Battery Switch: 2 Circuit Breaker 125A?
12 MC4 Connector for Panels male and female
1 Earthing complete Kit 25m
1 Individually Designed System installation Kit
1 Control Cabinet Studer X-connect
8 Earthing Cable Kit with Ring Terminals
15 PVC Cable Conduit ?
2 Aluminum Profile Bar Kit for Inverter Mounting
1 Changeover Switch Moeller 63A
1 Battery Rack Kunstmann
6 AC Circuit Breaker
for clarification they have changed their price and please may you tell me how much they might cost to complete all the system thank you
Andrew,
No problem--People post here when they have time.
I am not in the solar business--Just a (more or less) retired engineer who tries to help folks with questions.
I am in the US, and not familiar with most of your brands and equipment (European mostly?).
Buying a system from Europe for use in the US--Will hit you with high European taxes and US Import duties (not cheap either)--Plus getting support and spare parts in the US will be a long supply line (lots of delays, shipping/payment issues, etc.).
It sounds like somebody designed a system for your needs (this is not a small system). I would suggest that you contact various distributors directly (located, at least, in the country of where the equipment will be installed). for pricing/availability.
Some distributors will pre-wire and test systems--Helpful if you will be installing the system in a remote location (away from stores/sources of components). And making sure that nothing is missing.
I am not sure I can really give you much more help unless you have questions about your basic system (enough batteries and solar panels for your loads, a good backup genset--if needed, etc.).
Thank you my brother but general answer you tell me how much does it cost approximately without the taxes..
and yes the system was designed for my needs may you tell me please in advance generally how much around this will cost thank you
-Andrew
Just picking rough equivalent parts--~$53,000, not including racking, wiring, grounding, addition I/O interface (Mates) for Outback hardware.24 Panels: SILLIA 320 W. POLY
Kyocera KU340-8BCA ($320 each)
Surrette Battery - 2 Volts, 2430 Amp-hours ($1,176 each)
Midnite Solar MNPV6 Solar Array Combiner (6 circuit $88.50)
Outback Flexmax 80 Amp MPPT Solar Charge Controller ($550 each)
Outback Radian GS8048A 8,000 Watt Advanced Inverter/Charger ($4,145)
Outback Power Flexnet-DC System Monitor ($275)
GSLC175 Prewired Load Center PV/120/240 for Two Charge Controllers ($1,230)
Above total ~$52,831
I am not saying this is a properly designed and configured system--Just a list of parts for rough pricing.
Our host, NAWS will do detailed designed services--Including complete bills of materials and pre-wired/pre-tested systems.
But--That is NAWS, not me. I am not in the business and I do not work for NAWS.
thank you for your explanation and i would like to know please if you know NAWS work out of the USA.
Also, how can you calculate the load for the electricity you need for example how can i calculate the load for the building?
Can you tell us about what the system will be used for (on grid/backupbackup, pure off grid) and where installed?
Naws is in south west United States (state of Arizona). They do support out of USA customers too.
it is not clear what are the differences among these three types if you can explain them....
i want the whole system and connected to diesel generator or grid? and in Africa?
Thank you
-Andrew
OK, first is your power 230 VAC @ 50 Hz?
And, the Diesel Genset + AC charger (or AC inverter+charger) needs to be able to supply enough current to the battery bank for proper charging... For large industrial cells, generally 10% rate of charge minimum. If you have one string of 2 volt @ 1,957 AH batteries, that would be ~196 amps minimum. And the minimum genset should be:- 196 Amps * 59 volts charging * 1/0.90 charger eff * 1/0.95 charger power factor * 1/0.80 genset derating = 16,906 Watt minimum rated genset (typical deratings)
- 1,957 AH * 59 volts charging * 1/0.77 solar array derating * 0.05 rate of charge = 7,243 Watt array minimum
- 1,957 AH * 59 volts charging * 1/0.77 solar array derating * 0.10 rate of charge =14,487 Watt array nominal
- 1,957 AH * 59 volts charging * 1/0.77 solar array derating * 0.13 rate of charge =18,833 Watt array "typical cost effective maximum"
- 1,957 AH * 48 volt system * 0.85 typical inverter eff * 1/2 days storage * 0.50 maximum discharge = 19,961 Watt*Hours per day
- 19,961 Watt*Hours per day * 1/0.52 off grid AC system eff * 1/4 hours per day minimum sun = 9,697 Watt Array "break even" size
If your area has a lot of sun, and you are OK with running the diesel genset every day (or at least once per week) to help ensure the battery bank is properly charged (try for >90% state of charge every few to ~7 days, avoid lots of cycling below 50% state of charge) and/or you have lots of sun most of the year--It is possible your present array is large enough for full time off grid.
Your Studer AC inverter+charger only has a maximum of 100 Amp charging output--So, if you plan on 10% rate of charge, you would need a second inverter or a separate AC battery charger for ~200 amps of charging.
The above "rules of thumb" are based on C20 battery capacity rating... Your C20 rating (I think) is ~1,800 AH--So my numbers above should be a bit less.
http://www.batteriesdirect.com.au/shop/product/23648/ngs6021960hs0fac-(a602/1960c).html
Also, it appears your batteries are GEL/VRLA batteries. In the US, we tend to stay away from GEL batteries because of low charging current (5% rate of charge for C20 capacity). However, it appears that your batteries are rated to 35% rate of charge @ C10 capacity--And are designed/rated for solar charging (be careful not to charge a too high of voltage, and for warm/hot environments, you have to derate the maximum charging voltage). Here is the charging document for A602/1960 GEL type batteries:
http://www.sonnenschein.org/PDF files/GelHandbookPart2.pdf
I do not know much about European GEL/VRLA type batteries--So, you will have to work with your battery and solar charge controller suppliers to ensure that your system is designed correctly.
Hello Bill
you did not answer my question if NAWS can install solar panel in africa and how much price should i pay?
Andrew,
I do not work for NAWS... I am just a volunteer here (~800 miles away from Flagstaff Az, USA). You would have to ask NAWS directly. I simply do not know anything about NAWS other than what I see on their website and when they post here on occasion (and when working with them on Forum Software/operational questions).
BUT WHAT ABOUT THE BRANDS AND THE PRODUCTS TO ISTALL MY SYSTEM THEY HAVE TOLD ME THE FINAL PRICE FOR COMPLETE SYSTEM IS ALMOST 80K DOLLAR DO YOU THINK GENERALLY THIS IS GODD PRICE?
THANK YOU FOR YOUR UNDERSTANDING?
I don't know European Brands--I live in the United States and I never worked in the solar industry.
The brands you listed, as far as I know, are good (German?) brands. But I do not have any knowledge about their products.
The problem is, specifics. SMA is a very good German brand of inverters... But when a specific product is used in a specific application, sometimes problems occur (not pointing fingers--Just recent examples of people having questions).
SMA too sophisticated to be any good?
Weird Data from SMA Inverter
It can be design issues by the manufacturer. It can be design/installation issues caused by the local engineer/installer.
Is the system set up right
You can pay lots of good money on the installation, and have very poor results... Or even a great installation, and very poor maintenance/operational practices that cause the system to fail. A system operated by one person may work well--Same system and same loads operated by somebody else can fail to perform.
It takes dedication, training, and knowledge (as well as good equipment, system design, etc.) to have a sucessful installation. A failure in any one of those areas--And you can have $100,000 of scrap in a matter of weeks.
With the size system you are proposing--The vendor(s) should be able to give you references for similar systems that their products have been used in and have been responsible for installing. And check the references--Ideally in the area you will be installing the system--Has the system performed well, have they received support from the vendors/installers? Has there been any problems/issues--Especially unresolved issues.
and what about the price if 70000 USD is this good price for that system
thank you
I do not work for NAWS, or any solar vendor.
For large systems, understanding the basics can be Big help when talking with solar designers and sales people.
If this is your first system, that is Lot of money to be responsible for. There are a lot of details to get right. Get few wrong, and the system may have problems.
They will install it not me.
can you tell me the basic please?
and what are the details please ?
I am very sorry Andrew--I guess I am just getting you more frustrated.
I do not have any more answers than I have given above. We cannot give you a 1 year class (or a 4 year degree) on electrical and solar engineering in a forum. There are books and seminars (some very good ones are held by equipment manufacturers).
I suggest you find a local installer/engineer and interview them about your design. Trying to buy equipment and fly it several thousand miles to a remote installation can be very difficult and risky.
There are methods that can help. One way is to build the system where you live (in this case, perhaps buy a used shipping container). And setup it up/test/qualify. After you have done that, then pack up the solar array+genset+etc. into the container and ship the whole thing in one unit to the destination.
Regarding Solar Books:
What's a Good Beginners Book?
From the above thread:This is a link to a PV textbook I find very informative. It was a requirement for the FL contractor's exam I took last month. It even has a very good interactive CD with a bunch of informative extras. A quick search on-line shows this book goes for about $75.00 USD everywhere.
Don't forget nothing compares to OJT when it comes to installation. It's always best to apply in the field what you've learned from a good textbook first.
[URL="http://www.powells.com/cgi-bin/biblio?show=HARDCVR W/COMP MEDIA:NEW:*****26912879:75.00"]http://www.powells.com/cgi-bin/bibli...26912879:75.00[/URL]Rick,
Here a good "textbook" on solar......it actually IS a textbook for some solar courses, and is set up that way with practice questions at the end of each chapter, but it's also a good self guide as to the basics of components and how they mesh together to make a system. Worth the money, IMHO.
Solar Book HereSome information on NEC and how it applies to solar power:
PV and the 2005 NEC -- Reference Document
And, of course, the NEC Code Book (current edition or version that is used by your locality).
Book - The New Solar Electric Home
PPS: From another poster:KeithWHare wrote: »I recommend "Photovoltaics: Design and Installation Manual" from Solar Energy International. This does a pretty decent job of explaining everything except for battery banks.
Keith
PPPS: From another website, I saw this Boatowner's Illustrated Electrical Handbook recommended.
PPPPS:rollandelliott wrote: »according to wikipedia once it is adopted into law by a particular govt agency it becomes public knowledge
http://bulk.resource.org/codes.gov/ga_electric.pdf
is one link
there are many more specific to certain states/cities here
May 26th, 2013:ChrisOlson wrote: »I always recommend Hugh's recipe book
http://scoraigwind.com/axialplans/index.htm
It has the "plans" on how to build six different turbines. But Hugh also goes into the theory in explaining why the turbines are built the way they are, and it's written by a master that has spent most of his life working with wind power.
I don't know about the Otherpower book - I have only read excerpts of it and never the whole thing.
Chris
June 30th, 2013:ChrisOlson wrote: »Ed Lenz's website is probably the best resource for building a small microturbine. Ed has articles on there covering three-phase basics, along with several small windpower projects he has done, etc.
http://www.windstuffnow.com/main/
Chris
July 19th, 2013:Panamretiree wrote: »A good manual on boat electrics is: Boatowner's Mechanical and Electrical Manual: How to Maintain, Repair, and Improve Your Boat's Essential Systems by Nigel Calder. Goes through all issues that you can be confronted with, including solar, wind and hydro power. Has considerable information on grounding and bonding in a boat. Approximately $36.00 on Amazon.com.
Cheers
June 19th, 2014:
Both PNjunction and vtMaps have given a "thumbs up on":PNjunction wrote: ». you might want to take a look at this manual:
http://www.samlexamerica.com/product...il.aspx?pid=60
Covers FAR more than just the controller and goes into details about solar setups in general. Best I've ever seen, and devoid of hype. Highly recommended, ......
June 24th, 2014:Energy Unlimited by Victron is a good introduction: http://www.victronenergy.com/upload/...limited-EN.pdf focussed on marine systems but 90% same for land based off-grid.
February 10th, 2015HX,
This was an excellent resource I came across that addresses your question [wire insulation/temperature requirements]:
http://www.cooperindustries.com/content/dam/public/bussmann/Electrical/Resources/solution-center/technical_library/BUS_Ele_Tech_Lib_Conductor_Ampacities.pdf
Thank you
so much i am engineer and i used to live in Arizona
however, i would like to explain to you in details what i mean for clarification.
i won't ship anything. i will only sign the contract with them and they will complete the system from A to Z.,
now i would like to ask you for clarification is it 70000 USD good price for that deal?
Bill, you have done so much here! All I can add is,
Nigel Tufnel: The numbers all go to eleven. Look, right across the board, eleven, eleven, eleven and...
Marty DiBergi: Oh, I see. And most amps go up to ten?
Nigel Tufnel: Exactly.
Marty DiBergi: Does that mean it's louder? Is it any louder?
Nigel Tufnel: Well, it's one louder, isn't it? It's not ten. You see, most blokes, you know, will be playing at ten. You're on ten here, all the way up, all the way up, all the way up, you're on ten on your guitar. Where can you go from there? Where?
Marty DiBergi: I don't know.
Nigel Tufnel: Nowhere. Exactly. What we do is, if we need that extra push over the cliff, you know what we do?
Marty DiBergi: Put it up to eleven.
Nigel Tufnel: Eleven. Exactly. One louder.
Marty DiBergi: Why don't you just make ten louder and make ten be the top number and make that a little louder?
Nigel Tufnel: [pause] These go to eleven.
I personally prefer amps that go to at least 12. One step better than the Spinal Tap guys.Island cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year.
I have no idea.
Even if you pay $70k for parts, you may need to pay another $70k for design, labor, set up, test, break down, shipping, insurance, customs taxes, on site installation, etc.
This is not an inexpensive/low risk project.
706jim said:I personally prefer amps that go to at least 12. One step better than the Spinal Tap guys.
Thank you Bill
the company told me 70k USD included everything from A to Z and with also insurance for Maintenance
Sounds wonderful.
As always, check references.
Good luck,
- 651 Solar Water Pumping
- 608 Discussion Forums/Café
