New Samsung Inverter Fridge
simmtron
Solar Expert Posts: 87 ✭✭✭
Well just picked up a new Samsung inverter fridge for $320 to use in our new off grid house. We are finally moving out of the motor home into new house in the jungle so needed a fridge. To order a Dometic here in Mexico it would be $1700 so it was a no brainier. It leaves me with $1380 to buy more panels and batteries. And no more LP bills. It's only 12 CF but that's still 40% bigger than a Dometic. 310 kwh per year.
Well plugged it in and have my Kill-a-Watt meter hooked up. Started out at 11 watts then jumped to 32 watts then 55 watts now leveled off at 130 watts. This is from hot so I'll see how long it takes to cool down. After 10 minutes the freezer was already quite cold.
simmtron said:Well just picked up a new Samsung inverter fridge for $320 to use in our new off grid house. We are finally moving out of the motor home into new house in the jungle so needed a fridge. To order a Dometic here in Mexico it would be $1700 so it was a no brainier. It leaves me with $1380 to buy more panels and batteries. And no more LP bills. It's only 12 CF but that's still 40% bigger than a Dometic. 310 kwh per year.
What data would you be interested in? It is a model RT29FARLDSP Or RT29F . The later numbers are just differences from countries, I think.
I have the 340 l model . been going for a year and a half . Pleased with it .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
It was interesting in doing research on fridges, I was looking at Sun Frost fridges 110 volt and although they are super expensive $3300us, they are now no more efficient than A store bought fridge.
My wife suprised me and got a similar fridge. She went shopping for a refrigerator and came back with the inverter refrigerator. At the time was I believe around $500 usd. I am also in mexico. Exchange rate was not as good as it is now.
Just found old post. Over 2 years old. No problems other than too small
Http://forum.solar-electric.com/discussion/comment/307046#Comment_307046
Thing about the size of a fridge, doesn't matter what the size you will always overfill them.
null
Where in Mexico are you? -
Was in quintana roo. But last few years in the yucatan. Starting a small off grid ranch. Hopefully live there with in a year. Like you probably know everything takes forever. Feels like a never ending money pit. But this upcoming year hopefully costs are covered by income.
In Quintana Roo outside Playa.
Does this run ok on modified sine power?Island cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year.
706jim said:Does this run ok on modified sine power?
If a gadget cost's more than $80, I would only run it off a pure sine inverter
Simmtron, have you measured kilowatt hours/day? And at what ambient temperature?
Desert Rat said:Simmtron, have you measured kilowatt hours/day? And at what ambient temperature?
- 228 Forum & Website
- 653 Solar Water Pumping
- 618 Discussion Forums/Café
