Need to get educated about magnets
I just read the article on Jay leno wind turbine. Where can i find out more about rare earth element magnet use to generate electricity for wind. Any which mfg. make permanent magnets using rare earth elements ? for the home user or small wind farm.
Re: Need to get educated about magnets
Edmund Scientific's world of magnets may be a good place to start, but if you need even more, I'm sure there are places on line you can find for less. http://tinyurl.com/2wvcs8
EYEBALL CAUTION : The super magnets are VERY powerfull, and Extremely brittle. If you lose one, it WILL fly to metal or another magnet, and shatter into glasslike shards. Don't let your skin or eye get in the way.
PS You may find this site informative too http://www.builditsolar.com/Projects/Wind/wind.htm
another source: http://www.wondermagnet.com/Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
jay leno article : http://www.popularmechanics.com/automotive/jay_leno_garage/4216780.html -
Energy from the wind needs wind in addition to equipment. Accordingly, you might want to research wind resources in Ohio before going too far down the wind road. See: http://www.eere.energy.gov/windandhydro/windpoweringamerica/where_is_wind_ohio.asp
HTH,
Jim / crewzer -
Ohio is not that bad for wind , except where i live. This research is more for friends who live in south america. Planning on going down their to install alternative energy - wind , solar.
