Has anybody used one of these?
http://www.ebay.com/itm/LCD-MPPT-Solar-Regulator-Charge-Controller-24-36-48-60-72V-10A-DC-DC-Boost-L4H4-/322052122975?hash=item4afbcd695f:g:MksAAOSwZ8ZW9OVV
I doubt that any country could make an MPPT controller for $34 in components and ship it from China to your door.
Might I suggest that you run the other way!
So to answer my question , you haven't used one of these. Thanks for your 2 cents.
A 10A MPPT controller would generally not require a fan, No battery temperature sensor, but the paint is green
Yes, Mike, but its a pretty green.
10A? and 60v input max... any modern, normal house-sized panel would be around 35v and close to 8A output... near maxing out this controller. So if that's all you need, then its not much to risk... but I think most people would want a bit more power than that to be really useful, unless you are only running small ancillary devices and not true household appliances. Very limited utility.
