240 volt issue
Thank you in advance.
The sponsor of this forum has this..... http://www.solar-electric.com/psx-240.html
Am Outback auto former for 240 from 120...
I looked at the PSX-240 and it says you must have 2 inverters stacked, OUTBACK programmed stacked (vs. classic stacking), or two separate in phase 120v circuits (by the owners manual). Would the magnum 4024 be considered 2 different in phase 120 circuits?
Creolin said:I looked at the PSX-240 and it says you must have 2 inverters stacked, OUTBACK programmed stacked (vs. classic stacking), or two separate in phase 120v circuits (by the owners manual). Would the magnum 4024 be considered 2 different in phase 120 circuits?
I think you are looking at the step down setup, to step up from 120 to 240, the diagram only shows one 120 line in...http://www.solar-electric.com/lib/wind-sun/PSX-240-manual.pdf
Nope, it does both..first point in the Highlights on this page....http://www.outbackpower.com/outback-products/integration-hardware/item/autotransformer
Also page 5 point #1 of PhoptoWhit's link
Thank you guys for your advice. Guess I am ordering a PSX 240.
Is it possible to get the A/C unit exchanged to a different model (120 VAC only)? The other option would be to get a 120/240 VAC inverter.
A/C systems (and even refrigerators to a degree) are two big drivers to "bigger" solar power systems. Do you have a good estimate on how many kWH per day you plan on using? Will you have utility power and "backup solar power" -- Or is this for an Off Grid system?
There are modern Mini-Split systems that have inverter based compressors--Which are very "solar friendly"--But most of them seem to be ~240 VAC units now (the older 120 VAC smaller mini-splits seem to have "gone away"). Also, there are heat pump versions that can do cooling and heating--Something that can even work pretty nicely even on solar power systems (at least during sunny winter weather).
Creolin said:Thank you guys for your advice. Guess I am ordering a PSX 240.
I'd have a serious talk with the guys who told you it was going to be 120 volts only. You could have purchased a 120/240 volt inverter for just a few dollars more. I'd suggest they should at very least split the cost of the autotransformer!Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
what about the Solar retailer, can you trade the 120 v inverter for an upgrade to 120/240? After the 120V 'chat'!
I remember seeing transformers up/down 120-240V that have a capacity of 2kW and would do what you need from them. Less than $100.
Sunpower 3 x 435 watt panels, 48 v 215 AH battery bank (Sam's club), Midnite Kid and WBjr, Fujitsu 9RLS3 split duct AC, Outback FX 3048T + transformer 2000W 120/220V, GrapeSolar Fridge. -
I am still arguing with the people that sold me the house and told me that it was 120 v only (to either replace the units or help with a new inverter). The 2KW system would not work (AC units alone can pull 3250w). The ones installed are a mini-split system. When I was purchasing everything, that is why I had asked about the 120 versus 240 in the tiny home. Figured I would save a few dollars and buy the cheaper inverter if 240 wasn't needed (MISTAKE). I began purchasing all the solar stuff back in January and my tiny home was finally delivered the first week of April (after several delays). So too much time has gone by to exchange anything. Yes, I have the sizing down, actually, I have way too many solar panels (over 6 KW/hr) for what I need and have over 20 KW of battery storage. Best I can tell right now, I am only using between 5-8Kw/day (Of course, that is with a generator and not the solar panels/batteries.)
For a well insulated tiny house, I doubt you'll need an a/c that draws that much energy. I would think a 24000 btu mini split would draw less than 2,000 watts. Might check your figures. That would be a higher cooling capacity than 4 of my window units that draw less than 500watts and could cool up to 800 square feet. Though perhaps we have a different definition of "Tiny House".
BTW-Mini splits ramp up slowly so don't have a huge compressor draw at the begining.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Well, this tiny house turned out to be nothing much more than a 399 sq. ft trailer, and insulated as such. I would not recommend buying from Tiny house outlet, tiny house direct, or legacy homes. The 2 split units are 7.3 amp/230v/60hz . They do work well off of my generator.
Something isn't right, Not sure what capacity you have, but even a bad mini split should be lower wattage for the cooling space. You will need a huge solar array to support that size load for any length of time. I don't have a small system and wouldn't want to try to run those monsters.
I'd like to a have a mini split in the main room of my 900 sq foot modular/mobile home. A 1200btu should be about right to cool the near 500 square foot main room and kitchen area and bad ones 14-15 seer units) run @1350watts you are looking at more than that to run less than half the space....
My 5200btu window unit cools a 16x14 room that's over 200 square feet, and runs around 500watts...
Something's not right!!!
If a AC unit is to big for a dwelling, the dwelling will get cool fast but the humidity will remain inside the dwelling which will leave you with cold humid air inside the dwelling.
The longer a unit runs the more humidity it will remove, the proper setting would be 50 to 50 or ....50% on and 50% off throughout a 24hr time which would give enough running time to remove moister and still cool you place while it preserves electricity.
A 5,000 BTU AC would be enough for a 399 sft dwelling and as Photowhit said already it will use about 500 watts per hr.
I use two 5,000 BTU units for a 1200sft 80 year old home and I have a 3rd unit as standby that gets used about 3 weeks a year.
Tell us more about the air conditioning system.
Why not use a window unit that can quickly, easily and cheaply be replaced?
What voltage is the DC side of your solar power system?
As far as I can tell you need at least 24volt to run a decent 240VAC pure sine inverter. 48v would be better.
Sounds like you have two roughly 1.4 ton units for 400 square feet which makes absolutely no sense what so ever. The people who built that trailer are completely insane, completely stupid or both.
Well, I finally got the sales person on the phone. It seems that they ran out of the original AC units that were being used. Their purchasing department bought a whole truck load from Florida. The installers just installed the new units and evidently no one told anyone in the sales or management of the changes. According to the sales person, they found out about the same time I called when they were setting up for a show and couldn't get the AC's to work. (At least thats the story I was told.) I am still going around with them about getting the units replaced or them to purchase the PSX240. I can use a window unit, but I just paid $25K. I expect them to fix the problem. These split units are also the heating units as well. One of them is more than a enough to heat/cool the whole house.
I haven't set up all the solar stuff yet. I purchased it all and it's sitting in storage while I get this crap worked out. But I have 20 x 330w solar panels (not planning on using all the panels right now), 16 6volt batteries (210amp hrs) (I was going to set them up in 24v config), a Magnum 4024 PSW Inverter,and an Outback 80A, -
Make sure you have float charger(s) for your batteries (or a traditional charger for 24 hours every 30 days minimum)... If they sit for more than 1 month without any charging, they will begin to sulfate and go bad (and if they are not fully charged now, they will will begin to sulfate even sooner).
Batteries that are sulfated are only good for recycling--They cannot be brought back to life (like new condition).
With sixteen 6v batteries wired up for a 24v configuration you're going to have 4 battery strings. I'm no expert but as I understand it running that many strings (3 strings max and 2 strings is better) will cause uneven battery charging. I'd be sure to use some very heavy wires and connectors to help even out the charge between the battery strings.
48v Rolls 6CS 27P
You can connect more than 3 battery strings together--I just recommend that you look for other options (higher voltage battery bank, using larger AH capacity batteries/cells, etc.).
If you already have the batteries+hardware--You might as well use them. This will be a learning experience for you.
